Thread: Whyoming
    Question
    Code:
    Rheem RAPC 14 SEER 3-ton
      vapor line 3/4" [19.05 mm] O.D. Opt.
                 7/8" [22.23 mm] O.D. Std.
               1 1/8" [28.58 mm] O.D. Opt.
    Assuming under 25' length, if you use an existing 3/4" vapor line (as opposed to the 7/8" standard specified), about how much will that affect performance/capacity ??
    thanks
    Seems that most 3-ton AC use 3/4" suction line. Some are 7/8". Why do they use 7/8 when 3/4 works for everybody else ?
    [Edited by LK on 09-19-2005 at 06:46 PM]
    Canada
    Unhappy
    WHAT
    Talking
    works and works Right are 2 diffrent things......if u wear a size twelve shoe...my guess is an eleven and a half might WORK............JMO
    If its worth doing, it's worth doing right.
