Results 1 to 8 of 8
    Nov 2010
    Thermostat Training Resource
    Can anyone point me in the direction to some good training on Tstat replacement? I am running a program where we will have electricians doing some wiring and then replacing the Tstat in customers homes. I need some good general training materials.
    Any help is appreciated.
    my money says they can't do it, it's more than 3 colors and they don't always match up
    Urbandale IA. USA
    It is like MOST companies use RED for the 24v supply, but company B uses WHITE just to discourage OTHER companies from working on THEIR equipment.
    Then UNCLE JOE does NOT care what color goes on what terminal and hooks them up any old way.
    NOW how are you going to train an electrician to determine who and how the THERMOSTAT was hooket up?
    Those who dance, appear insane to those who do not hear the music.
    Those who believe, appear ignorant to those who do not know God.
    Oct 2010
    SW Michigan, near Battle Creek
    thermostats come with wiring diagramns.
    a electrician should be able to figure them out.
    that said we all have stories about fixing electrician caused messes
    Dec 2001
    Ocean Pines, MD
    If all else fails try using the install manuals.
    Oct 2010
    who' t-stats are you using
    seems honeywell or white-rodgers would love to get their name in thes if it is big enough
    New Mexico
    Where controls are concerned I always tell the electricians to go ahead and run the wires but I'll terminate. They usually look relieved.
    The other problem even with them running the wire, often it ends up #12.
    Give me a relay with big enough contacts, and I'll run the world!
    You can be anything you want......As long as you don't suck at it.
    If a person wants to create a machine that will be more likely to fail...Make it complicated.
    USAF 98 Bomb Wing 1960-66 SMW Lu49
    Jun 2010
    Philadelphia PA
    Email me @ profile info
Tags for this Thread
Contracting Business
HPAC Engineering
EC&M
CONTRACTOR
