I have tried to do this alson. could not find a way. good luck.
I just Replaced ZN 517 board on a york unit the old ZN 517 board was bad. There is a trane tracker on job site this is a com 5 system, I pushed the service pin and the tracker located and installed the new board what I need to know is how to delete the old controler out of the tracker or replace the old info with the new info in the tracker there is a option to replace the old with the new but when I go to this option the new board is not in the list does anybody have a book or info on this
Traker 24
version 10.00.366
Hardware version 1
Software version 2.8
After changing the ZN controller you need to push the service button, then go to the Tracker panel ( can't remember the exact button to push ) and replace device, it will ask you what device you want to replace with. If no devices show up to be replaced with you will have to reboot the Tracker to factory defaults, when you do this you will loose all TOD schedules and binay output programming all setpoint controls will default to local not Tracker control.
The best thing you could do is upgrade the image on that panel to V12, when you do this you will also have to reprogram the TODs and binary progamming anyway.
Brought to you by the school of hard knocks!!!!!!
If this is the new Tracker touch screen controller, you need the new Tracker software for your laptop, then you can go in and delete the old zn517.
Tried that last week. Can't do it.Originally posted by bku46
I have done it, I could tell you Qtip but I dont like you.
Same here!!! You better call St. Paul cause they don't know how to do it either.Originally posted by bku46
This is for Biscuit eater.
Listen up Qtip, you might learn something.
This is how you replace a comm 5 device with Tracker ver 12.00
Go to setup menue
Go to panel setup
Go to comm 5 tab
Select device to be replaced and select it.
Select replace button
Replace with the new comm 5 device
Refresh and thats it.
Some guys are so smart, they are stupid, right Qtip??
Explain the above statement.Originally posted by bku46
Yes you can replace a device through to touch screen very easily. But if the Tracker panel sees it as a new device before you try to replace it you can not delete it from the data base with out rebooting to factory defaults.
Glad to see you can read and IOM.
He,s replacing a old device with a new device, try listening to the problem before you trip over your feet.
Qtip you are a a hole. dont reply to my threads unless you have your facts straight.
BKU46: Does the name DICKHEAD mean anything to you??? Or maybe Mr. Dickhead. In my thirtysome years in this business one type tech I have no stomach for anymore is F---K no it alls. I hope you rest in pieces>
We are here on Earth to fart around ......Kurt Vonnegut
You can be anything you want......As long as you don't suck at it.
USAF 98 Bomb Wing 1960-66 SMW Lu49
After 30 years in the bussiness, you seem to know nothing. Please you need to retire old man, the field has past you by years ago. hey, isnt past your nap time??
bku46 is a homo who cant handle the fact that ddc control isnt hard, and everybody is learning it. your days of having people treat you like your something special are over, get used to it colon cowboy
Actually BKU just gets off on stirring it up a little bit. It is obvious he has no idea about what he is talking about, but just likes to draw attention to himself. Just ignore him and do not give him any acknowledgment. He really is not worth the effort.
If all else fails....Try reading the directions!
Tell it like it is and let the chips fall where they may.
Any views or opinions stated here are strictly my own.
Its like this guys, I get attacked, I fire back, I try to help people and then I get other guys sticking there two cents in where it dont belong. Got It Pal.
i was gonna try to help since Darryl ain't here no mo .... but .....it's way to hostile now !
Read back through this post and you will see who started attacking who!!!!Originally posted by bku46
Get off you f-ing horse BK and grow up.
Do you have any friends in life or do act the same way to them!!!
That is my rant................get over your attitude.
Oh and have a nice day!!!
Deleted by me.
[Edited by plain spoken on 09-07-2004 at 07:46 PM]
poor Don is probably lookin' for the "edit". or "delete" key right now !!!
made the same mistake about 2 months ago, added a new device instead of "replacing" a device had to load version 12 on the traker and call for help lol but the old device can be deleted with version 12 was told that this is the first version that can delete devices seen I know next time I'll remember to replace it's a lot less work
