Results 1 to 15 of 15
Thread: TAR weight of 410A cylinder
    Jul 2009
    Can someone tell me what is the TARE weight (empty weight) of a 25 lb tank of 410a? That is an empty tank of 410a with no freon in it?
    thanks in advance.
    No.
    You can, however.
    The Tare Weight (TW) is stamped into the cylinder somewhere.
    Each cylinder is slightly different.
    Virginia
    New virgin refrigerant cylinders (25/30lbs) only have a net weight labeled on them - in the case of your 410a cylinder, it's 25lbs.
    A full 410a (25lb cylinder) weighs about - 34lbs 2 oz (gross weight)
    subtracting the weight of the refrigerent - 25 lbs 0 oz (net weight)
    so the approx. empty container weight - 9 lbs 2 oz (tare weight)
  4. Likes nathankerr, Disabledsparky liked this post.
  5. #4
    Jan 2010
    No.
    Cylinders with the bail style handle weigh different than the stamped type handles. Recovery cylinders have tare weight stamped. And if your cylinder has (tar) on it say from some roofer who knows. Just joking Too Tall
  6. #5
    Breslau, Ontario
    each cylinder is slightly different, the tare weight will be stamped on the handle
  7. #6
    Jul 2009
    Thanks to all for your help. I'm an apprentice tech learning the trade. Your help and advise is greatly appreciated. I looked all over the darn cylinder but didn't look on the handle. ha. thanks.
  8. #7
    Mar 2018
    Negative. Not ALL of them do- I’m sitting here staring at one- that’s the reason I entered this thread. Especially the newer cans. I ordered one from amazon also with NO Tate weight anywhere to be found 👍
  9. #8
    Jun 2019
    You’re an idiot, that tank does not weigh 10 lbs...🙄
  10. #9
    Mar 2018
    You’re calling someone an idiot from a post that’s from 2010!!! 😂🤦*♂️
    Pretty sure he’s not going to care-
  11. #10
    Jul 2018
    Wisconsin
    Is his math incorrect? Looks good to me. Your first post you call someone a idiot.
  12. #11
    Mar 2018
    This was his first post!? Wow- amazzzzzin
  13. #12
    Jun 2019
    Hey guys I’m sorry, I haven’t had an opportunity to use the site. A co-worker was using my phone to research 410a charging temps and made a comment. That’ll be the last time he used my phone. I just joined the group and wouldn’t think of calling names. My sincere apologies-TJ
  14. #13
    Mar 2018
    Stand up guy,
    Much appreciated. I know I understand- it’s happened to me before- 😂
  15. #14
    Jun 2019
    By the way, an empty 410a cylinder weighs 9lbs.... hope this helps👍🏼
  16. #15
    Jan 2010
    Nobody uses my phone except me.
    And yes a R410a cylinder weights more because of it's pressure.
