Results 1 to 12 of 12
    May 2009
    Illinois
    Confused Command Aire Old Model Numbers
    I am trying to find out any information on an old Command Aire Water source heat pump that I can. Any help would be appreciated.
    Model # SPHD101911H10BC310100000020
    Anyone have any suggestions?
    Ft Wayne IN
    Trane bought the Command Aire line. Call 254-299-6300 for info.
    May 2009
    Illinois
    Thanks, I will try that.
    Aug 2009
    LA
    I have some old command-aire units from 1985 still new in their original boxes.
    model # SWP 354EA. They are vertical units.
    Virginia Beach
    does anyone have nomenclature information? i.e. SWPH 107 or SWPH 254. Trying to figure out nominal capacity.
    Jun 2010
    Quote Originally Posted by deminimus View Post
    I have some spec info sheets on SWPR 261 thru 611 water source heatpumps. typically the 261 indiates capacity:
    261 = 24000 btu
    281 = 30k
    361= 36k
    411 = 42k
    511=49k
    611= 62k btu
    some info here:
    http://www.waterfurnace.ca/Engineer/...cification.pdf
    http://www.waterfurnace.ca/Engineer/...Command%20AIRE
    Quote Originally Posted by vmurillo View Post
    i have a command aire model swpr 351 that needs replacing. I was wondering if u still had those units you were talking about and how much you wanted apiece for them. Any information would be greatly appreciated. Thank you.
    Jul 2011
    I have a command aire model # swpr 351gss that needs replacing or parts to repair.(leaking condenser coil ) is the 354ea about the same product? and how much you asking for them. thanks
    Nov 2011
    I am trying to find out any information on an old Command Aire heat pump # SWPV 301. Any help would be appreciated.
    Jan 2015
    Do you still have any of these units
    John 508-726-9305
    Jul 2015
    Command Aire units
    If you still have Command Aire units, I am interested in one. Please contact me.
    Jul 2015
    Did you get a reply about old Command Air heat pumps from the guy that said that he has some 1985 models still in the box? I am needing one too. 801-427-7872
