+ Reply to Thread
Results 1 to 13 of 13
Thread: Ice machine problem
    Aug 2019
    Ice machine problem
    Kml-500mal
    Ice dropping but getting stuck .cousing to accumulate to a big iceberg and cycle start again
    Southold, NY
    Have you gone thru the Hoshizaki freeze up sheet?
    Oct 2011
    Harrisburg, NC
    *shifts the trajectory of human existence away from said ice machine”
    With the state of the world, I think we would steer clear of anything that mentions “iceberg”.
    I can't fix it if it won't stay broke..
    LEHIGH VALLEY, PA
    Consider not all ice drops and laves the plate cleanly. It only takes 1 strip / section to stay during a harvest or partially detach , to cause a freeze up . There freeze up sheet is a start , look carefully at evap condition , plate separation or evap curve happening . Check carefully water flow and make sure the machine is CLEAN . When ice leaves the plate it drops on to the plastic deflector grid, is it placed correctly, any sections cracked off.
    Aug 2001
    After checking all other possibilities you may want to extend the harvest cycle. In winter conditions sometimes the incoming water temperature may not provide enough heat to assist properly in the harvest cycle.
  6. Likes COOLJIM liked this post.
  7. #6
    Aug 2019
    Quote Originally Posted by COOLJIM View Post
    Machine is fully clean When ice leaves the plate it drops on to the plastic deflector grid and one piece gets stuck the ice cycle start again with the piece left there there are no broken pieces on the deflector. Now a friend was telling me it needs refrigerate because the hot gas needs to drop the ice .not the water ?
  8. #7
    Southold, NY
    Quote Originally Posted by Lopez686joel View Post
    Follow there Freeze Up Sheets!
  9. #8
    Virginia
    If the freeze up sheet doesnt help ... you can move the Dip Switches to make it harvest longer
  10. #9
    Jan 2010
    Sounds to me like it might be to thick if a complete roll is not breaking up at the deflector.
  11. #10
    On a bull named Foo Manchu
    Have you tried shaking it
  12. #11
    Oct 2011
    Harrisburg, NC
    Or slapping it like an old TV?
  13. Likes Restaurant Mech liked this post.
  14. #12
    Oct 2009
    Raleigh, NC
    Make sure the cube guide isn't warped in any direction, especially along the lower edge closer to the drop zone. Place it on a flat surface and visually check that it is flat in every direction along the lower edge. If it bowed even just a little, it can hang up a few cubes, and that is all it takes to start a back up of ice. It will generally be worse in winter when incoming water temps can be lower.
  15. #13
    Aug 2019
    I would clean the machine, then max out the harvest timer. Also make sure water inlet flow is at the correct GPM during harvest. Check for serpentine separation
+ Reply to Thread
Quick Reply Quick Reply
Register Now
Log-in
  • You may post new threads
  • You may post replies
