+ Reply to Thread
Results 1 to 20 of 25
Thread: Stupid Deli Case
    Oct 2002
    Southeast Ohio
    Confused Stupid Deli Case
    Got a call today Deli case not working, I get there customer has a small Deli case 6 ft. I take front and back covers off to see condensing unit but
    that is about all I can do is see it. I hear the compressor over load clicking . They built this thing so the condensing unit can't be slid out the unit is
    hard piped in place with no room to work on it. I looked at tag on case the first two letters of the name are missing. I never did figure out a way to get
    in to compressor to check it. Busy day several calls to run so I left for now. Good part about it unit is only 10 months old, maybe someone else will
    get to fix under warranty. Have you guys seen one like that how did you work on it.
    Oct 2011
    Chicagoland Area
    Model# ?
    Why is it that those who complain the most contribute the least?
    MONEY CAN'T BUY HAPPINESS. POVERTY CAN'T BUY ANYTHING
    Jan 2010
    Chinese ?
    Aug 2013
    Omaha
    Can you give us something to work with tho man?
    Pictures...compressor make and or model...etc?
    Sent from my SM-G975U using Tapatalk
    Jan 2010
  6. Likes R600a liked this post.
  7. #6
    Oct 2002
    Southeast Ohio
    when I go back .Like I said tag on case is missing letters. Just venting for now.
  8. Likes UmmScott liked this post.
  9. #7
    Jan 2010
    Take pictures
  10. #8
    Oct 2002
    Southeast Ohio
    will do. May not have to go back if under warranty.
  11. #9
    Jan 2010
    Quote Originally Posted by coyote View Post
    Personally I steer away from warranty work.
  12. Likes UmmScott, Snapperhead liked this post.
  13. #10
    Oct 2002
    Southeast Ohio
    Went back to this deli case today they couldn't get anyone else to look at it either. Model #ERCD48 Manufacturer is Leader anybody ever work on one. Or know where I can find a
    Manual. Soon as I can get pictures loaded to computer I will upload them. Wasn't real busy today so I took some time and looked at it turned out loose wire. Now I will have to
    work on it till I retire they will say you worked on it before.
  14. Likes R600a liked this post.
  15. #11
    Oct 2002
    Southeast Ohio
Size:  2.49 MBName:  20210210_162404.jpg
  16. Likes VTP99 liked this post.
  17. #12
    Southold, NY
    Leader is made by Chinese in Brooklyn NY
    Really Basic shit.
    Clear the sight glass
    Install a defrost clock
    Set a 20+ difference in the stat and insert the probe in the coil.
    If your good you can operate off of a LP Control.
  18. Likes UmmScott liked this post.
  19. #13
    Oct 2002
    Southeast Ohio
    Yes but how do you get to the compressor start relay or anything else in there they don't even have extra line so you can slide it out to work on it.
  20. #14
    Oct 2011
    Chicagoland Area
    They got it in there, there has to be a way out.
  21. Likes VTP99 liked this post.
  22. #15
    Southold, NY
    Turn sideways.
    Put a small loop in the line set.
    I didn’t make them, there really not that bad. There are worse.
  23. Likes R600a liked this post.
  24. #16
    Jan 2010
    Worse one is a Delfield pie case !
  25. #17
    Jan 2010
    Sea to Sky
    Pull charge. Cut lineset. Reconfigure unit to allow service access. Then do everything Pecmsg said. If the customer doesn't want to do it...walk.
    You didn't build it, install it, engineer it.
    Sent from my SM-G965W using Tapatalk
  26. #18
    Southold, NY
    Quote Originally Posted by BALloyd View Post
    Most have a high side valve for pump down.
    There cheap but usable
  27. #19
    Jan 2010
    They sell braided lines anyone ever use them ?
  28. #20
    Oct 2002
    Southeast Ohio
    I thought braided lines was for vibration. Use to see them on K body compressors all the time.
+ Reply to Thread
Quick Reply Quick Reply
Register Now
Log-in
  • You may post new threads
  • You may post replies
