Unico Launches Twist-Fit System
New supply tubing simplifies and reduces installation time.
More...
50% reduced install time is quite significant. How interested would contractors be for reduced install time for smart tstats?
Post Likes - 1 Likes, 0 Dislikes
Well,,, 50% less install time in regards to the sound attenuator/metal. It is not necessarily the whole duct and air handler system. They have also changed the chemical composition of the attenuator and have introduced "green sugar" i am told and the last 2 we did both complained of a sweet smell for quite a long time. I have done several unicos the last few years in different applications and the twist fit is definitely a time saver tho.
As for smart thermostats the best thing i would like would be a toll free number for the customer to call if they have any settings, questions or problems with the stat and provide a damn book with useful information for the unit for the customer to reference
Sent from my SM-N960U using Tapatalk
Originally Posted by
BeachMaster
I would not be interested in reduced install time. I would prefer more hidden settings and configurability.
Sent from the Okie state usin Tapatalk
"Is this before or after you fired the parts cannon at it?" - senior tech
I'm tired of these mediocre "semi flammable" refrigerants. If we're going to do it let's do it right.
Unless we change direction we are likely to end up where we are going.
"It's not new, it's better than new!" Maru.
This is a clear promotion, I think.
It says 'Tubing is supplied from the factory with couplings already attached, reducing installation time by up to 50%'. For me, it means just a 50% of a fraction of the whole installation time.
'Like all Unico systems, the Twist-Fit System removes 30% more humidity from the air, allowing homeowners to set a thermostat at a higher temperature, reducing energy costs.' - energy reduction sounds attractive, as it should.
I bet, customized system with proper and longer installation time worth it as a long time assert.
