+ Reply to Thread
Results 1 to 11 of 11
Thread: Found this on reddit. Apparently its a Diakan unit...... WTH
    Sep 2012
    Hope this does not become common to save on power distribution blocks.
    Name:  diakin chiller.jpg
    Who’s to blame?... if you’re looking for the guilty, you need only look into a mirror. I know why you did it. I know you were afraid. Who wouldn’t be? War, terror, disease. There were a myriad of problems which conspired to corrupt your reason and rob you of your common sense. Fear got the best of you, and in your panic you turned to the now high chancellor, Adam Sutler. He promised you order, he promised you peace, and all he demanded in return was your silent, obedient consent. V for Vendetta
    Oct 2011
    Chicagoland Area
    That's the new TechZapper 3000
    Why is it that those who complain the most contribute the least?
    MONEY CAN'T BUY HAPPINESS. POVERTY CAN'T BUY ANYTHING
  3. Likes Lahrs, kdean1 liked this post.
  4. #3
    Sep 2012
    It's weird to see the power being fed to the bottom of that first breaker.
  5. #4
    Mar 2013
    NJ
    Daikin Factory reps I've worked with have and use flash PPE on those big boys.
    Times are changing.
  6. #5
    Dec 2020
    daikin
    Quote Originally Posted by Elfshadow View Post
    This configuration has advantages and disadvantages
  7. #6
    Dec 2020
  8. #7
    Jul 2013
    Richmond, VA
    Quote Originally Posted by sean770417 View Post
    Is the advantage your brain gets cooked first when you lean in?
  9. Likes dieseldude liked this post.
  10. #8
    Nov 2014
    OR
    That’s kinda cool
  11. #9
    Float'N Vally, MS
    This seems to be INSIDE of an enclosure..
    Seen it before.
    Life is too short, Behappy!
    TFMM
  12. #10
    Nov 2011
    CO
    I see stuff like that in bigger equipment all the time.
    technically, you're not supposed to have the door open with anything energized in that cabinet.
    If the door is open with that unit energized, you should have full arc flash protection on....including arc rated overalls, helmet with face shield, glasses, rubber and leather gloves, and maybe a full head covering and ear plugs.
    the ones I don't like are the older air cooled tranes that you have to remove all the screws on the panel covers to get to the high voltage sections.....waaaayyy too much crap in a tight space in those units.
  13. #11
    Float'N Vally, MS
    Quote Originally Posted by 71CHOPS View Post
    I have a friend who works in a large plant.
    He is the head HVAC guy and they cannot open ANY HVAC control panel. He has to have an (dressed out in full arc flash) electrician open any panel that may contain voltage.
    A simple after hours callout turns into a 6 hour ordeal.
    TFMM
+ Reply to Thread
Quick Reply Quick Reply
Register Now
Log-in
  • You may post new threads
  • You may post replies
