+ Reply to Thread
Results 1 to 11 of 11
Thread: Old evap airflow
    Sep 2003
    Old evap airflow
    Old R12 walk-in cooler. One square evap with fan on the bottom. Fan blade broke. Is it draw through as in discharge down or blow through?
    Oct 2011
    Harrisburg, NC
    Sounds like a low profile. Blows up through the coil and out the sides.
    I can't fix it if it won't stay broke..
    Jun 2010
    Midwest
    Quote Originally Posted by BadDaddy420 View Post
    That is a CENTER MOUNT coil -- not a low profile. A low profile coil is the typical evaporator you see in most walk-ins on a wall.
    Oct 2011
    Chicagoland Area
    Generally if the fan is on the bottom, the fan is on the inlet side of the coil. Easy way to tell is to stick a flashlight on the inside and see if it's dirty.
    Why is it that those who complain the most contribute the least?
    MONEY CAN'T BUY HAPPINESS. POVERTY CAN'T BUY ANYTHING
  5. Likes WT70, stumpdigger, sammyray, COOLJIM liked this post.
  6. #5
    Mar 2015
    Medford, N.Y.
    Quote Originally Posted by 2sac View Post
    X2,2sac
  7. #6
    Oct 2011
    Harrisburg, NC
    Quote Originally Posted by bohncoils View Post
    Yeah, that. I do that all the time. I knew what I meant
  8. Likes 2sac liked this post.
  9. #7
    Jun 2020
    BAIRD, TX
    and that helps us how?
    " The more I learn the more I realize how much I don't know"
  10. #8
    Jun 2020
    BAIRD, TX
    you can look at label on motor for rotation, bump motor for rotation, check where dirt is on prop, i useally take prop to supply house and match up best as possible.
  11. #9
    Apr 2008
    Michigan
    You guys are assuming its the original fan blade and motor. Those may have been changed to an incorrect one. Ive seen lots of times coils with multiple fans, some spinning CW and some CCW. Wrong pitch blades, too small etc. Supply us with a model # or pics!
  12. #10
    Oct 2011
    Harrisburg, NC
    Quote Originally Posted by stumpdigger View Post
    OP asked which way the air flowed.
  13. #11
    Jun 2020
    BAIRD, TX
    Got it, thanx
+ Reply to Thread
Quick Reply Quick Reply
Register Now
Log-in
  • You may post new threads
  • You may post replies
