Results 1 to 8 of 8
Thread: plannninnnnnnnnnnnnng to smoke a turkey
    mesa arizona
    Confused plannninnnnnnnnnnnnng to smoke a turkey
    WHAT WOULD RECOMMEND TO USE AS FLAVORED WOODCHIPS....AND RECOMMENDATIONS ON SMOKING A TURKEY..ANY GUIDANCE WOULD BE APPRECIATED............
    Desert Southwest
    What kind of smoker do you have? I have a Brinkman older style R2D2 and use Mesquite lump charcoal I get from Food City on Main and Stapley called El Diablo. Most of them and Bashas should have it.I buy the big 40lb bags for about $15. I'll soak some wood chips or add some firewood to get the smoke going. El Diablo is the real deal and actual trees that they turn into coal so the pieces are all different sizes some are large and 6" in diameter but they are easily made smaller by hitting them with a hammer or piece of wood or pipe. I drilled a 3/16" hole in the top so I can put a thermometer down into the turkey or whatever I'm smoking to keep an eye on the meat temperature. I prefer to keep the smoker temp to 175 to 225dgF for the first 90 minutes and add wood to keep the smoke going. Home Depot sells bags of wood chunks in Hickory and apple which are good. I soak them in the sink with a weight on them.
    http://www.eldiablocharcoal.com/
    If you can't fix it with JB Weld, Duct Tape, and Ty Wire it has to be replaced.
    No good deed goes unpunished.
    If you want to take off friday to go fishing then make sure you train your helper right.
    Oct 2011
    Chicagoland Area
    Brine it overnight
    Why is it that those who complain the most contribute the least?
    MONEY CAN'T BUY HAPPINESS. POVERTY CAN'T BUY ANYTHING
    Float'N Vally, MS
    Brine it overnight
    Or at least 4 hours. On bird brine use whatever you use and squeeze an orange in it.
    On bird I like a little hickory (what everyone is looking for) and Apple smoke.
    Life is too short, Behappy!
    TFMM
    Jun 2014
    Dover, DE
    Brine it, I’d suggest also spatchcocking the bird as well. Greatly reduces cooking time and the chance of the bird drying out.
    I havent failed. Ive just found 10,000 ways that wont work. - Thomas Edison
    Its not whether you get knocked down, its whether you get up. - Vince Lombardi
    "In this house we obey the laws of thermodynamics" - Homer Simpson
    Local 486 Instructor & Service Technician
  6. Likes crazzycajun liked this post.
  7. #6
    Jan 2010
    Sea to Sky
    Yep...brine it forthe win.
    Sent from my SM-G965W using Tapatalk
  8. #7
    Desert Southwest
    I did a 13 pound bird for for about 7 hours and it came out perfect, not the least bit dry.
  9. #8
    Nov 2020
    Are you sure that you want this?
