Results 21 to 26 of 26
Thread: Replacing seals for rack retrofit
  1. #21
    Jan 2010
    Sea to Sky
    Quote Originally Posted by BadDaddy420 View Post
    And new (yellow or blue) thread tape on relief valves while the receiver is empty. Don’t use white. The oil eats it up.
    I usually use pipe dope instead of tape on threaded connections. Rated for refrigerant, rated for pressures well in excess of standard system pressures and you don't have to pick out strands of tape from the threads when you change the reliefs.
    Sent from my SM-G965W using Tapatalk
  2. #22
    Quote Originally Posted by BALloyd View Post
    Personally I’ve never had a problem with Hercules brand Mega-tape and good old leak lock. Hercules makes good stuff. There’s something about blue monster brand tape I don’t like. Like it’s extra “slippery” or something. Mega-tape is king.
  3. #23
    Oct 2011
    Harrisburg, NC
    dave1234,
    I can give you the gasket part number for about any Sporlan part, even those pre 94/96 solenoid valves.
    And sight glasses, and this and that that I’ve accumulated over the years.
    As far as Carlyle, the oil level gaskets are common to any regulator. The seal where the adapter screws into the body of the compressor in place of the sight glass is Teflon. Nothing to change there.
    I can't fix it if it won't stay broke..
  4. #24
    dave1234,
    All good to know!!! I’m sure I’ll be in touch about that
  5. #25
    Nov 2014
    Western WA
    I personally like Loctite 567
  6. #26
    Jan 2010
    Sea to Sky
    Quote Originally Posted by GoCougs View Post
    No Loctite 554?
