+ Reply to Thread
Results 1 to 8 of 8
Thread: N4 Average function block and Missing inputs
    New York City
    Average function block in wire sheet takes in 4 VAV Room Temps and outputs an average
    We often loose a VAV Temperature out point.
    Example : 4 inputs each at 70 F. ,Total 280 Deg.F = avearge of seventy Degrees, Result = Space Satisfied
    now we have 4 inputs 3 at 70 F. One at Null ,Total 210 Deg.F = avearge of 52 Degrees F. ,Result= 100% heat
    Is there a block that can sense a Null Input
    This way I can disable the Average function block if we loose a Reading or two
    Kenilworth NJ
    I usually use switches and logic on the way into the average to monitor the temps and if it goes wonky, then throw a null. Or bypass the average block and do the math by hand. When one goes wonky it is divide by 3 instead of divide by 4.
    Hmmmm....smells like numbatwo to me.
    New York City
    I can make a Function to add the nulls an subtract them from the divide by N amount,
    but is there something that will differentiate from a Null value and an actual value?
    Jan 2002
    Fort Worth\Dallas, Texas
    Quote Originally Posted by techservices View Post
    Maybe I am missing something because a null value is ignored in the calculation of the average block.
    Go Rangers!
    Jul 2015
    New England
    Wiresheet isn't very pretty but you can do something like this with a StatusDemux block in kitcontrol > util.
    Jul 2009
    Westside
    What Jbeck showed there is similar to what I've done. Using the status demux to throw out any null conditions and switching it to a valid value.
    Mar 2018
    Quote Originally Posted by Jbeck00 View Post
    Call me crazy but it looks like your averaging block is outputting the correct answer already and your switch is giving you the wrong answer.
    Jul 2002
    strip out the highest and lowest?
+ Reply to Thread
Quick Reply Quick Reply
Register Now
Log-in
  • You may post new threads
  • You may post replies
