+ Reply to Thread
Results 1 to 14 of 14
Thread: Vaccum problem's
    Dec 2018
    Californa
    Vaccum problem's
    This is going to sound stupid been doing this almost 30 yrs went and changed a compressor.
    pressurized up to 155 pounds checked for leaks sprayed each joint. Did not lose pressure
    installed core tools did hi side and low side. removed core tools thinking they were leaking but i guess not still the same thing And yes I broke with nitrogen
    put on vacuum for just over an hour small system got down to 325 microns.
    but it would not hold a vacuum new hoses Fieldpeice mr45.
    The system still had a full charge upon recovery.
    Any idea's
    Salt Lake City/Tooele
    Vacuuming through your gauges?
    Mar 2018
    Virginia
    Redock your hoses to your manifold with the crt attached and vacuum the entire rig? Does it hold?
    "I think Quantum tunneling would work great... "
    "Call a technician for God's sake. Or we'll see you on the news or the Dark Side of the Moon."
    Dec 2018
    Californa
    Quote Originally Posted by slctech View Post
    First time yes 2nd time no still the same thing using all fieldpiece two different manifold's
    Nov 2020
    Spokane, WA
    In my experience you are not going to vacuum down to 325 microns if you have any sort of a leak, there has must be something with in the system still effecting the vacuum? If equipment is proven accurate. Then it may be the system. What does the vacuum rise to?
    Jan 2020
    Winnipeg Canada
    Possible moisture in system? Have you tried the old triple evac to see if it'll hold the microns?
    Other suggestion is nylog on fittings and not using manifold
    Chicago area
    Schrader without a cap? Like a unused port on evap?
  8. Likes R600a liked this post.
  9. #8
    Nov 2020
    Denver, Colorado
    Out of curiosity, did you end up losing the whole vacuum? Or did it break a certain point where you called it? I agree with a couple other comments about the possibility of there bein moisture in the system. The other possibility is there being a leak within whatever you are using as a micron gauge. I don't pull through manifolds anymore due to me having to waste time looking for a leak that was never actually there, and it being my hoses. Or the possibility of the micron gauge being dirty inside the manifolds.
  10. #9
    Jan 2019
    Vero Beach, Florida
    If you pulled to 325microns you don’t have any leaks.
    When was the last time you changed your pump oil? Is your micron gauge clean?
  11. #10
    May 2014
    Bay Area California
    What did the microns rise up to and how long did it take to get there?
    Quote Originally Posted by AVR2018 View Post
    Any idea's
    I do a triple evac with nitro to remove non condensables.
  12. #11
    Sep 2020
    midwest
    RIP OP
  13. #12
    Jan 2019
    Vero Beach, Florida
    Quote Originally Posted by YOUNG FROSTY View Post
    RIP OP
  14. #13
    Oct 2011
    Chicagoland Area
    Quote Originally Posted by Deathpunch0311 View Post
    and if you have a 2 stage pump and all you're doing is draining the oil, you're only removing 2/3 of the oil.
    Why is it that those who complain the most contribute the least?
    MONEY CAN'T BUY HAPPINESS. POVERTY CAN'T BUY ANYTHING
  15. #14
    Hurst11 is offline Professional Member/Membership Committee
    May 2020
    Haskell Oklahoma
    I’m gonna say oil in the evaporator or condenser and as it’s in vacuum a small amount of refrigerant bubbles out and it’s reflected in your micron reading. It’s hard to pull and keep an extremely deep vacuum on an existing system.
+ Reply to Thread
Quick Reply Quick Reply
Register Now
Log-in
  • You may post new threads
  • You may post replies
