+ Reply to Thread
Results 1 to 14 of 14
Thread: Furnace cleaning tips??
    Mar 2014
    When you guys go in for furnace cleaning do u cleanout all the pressure switch holes. If so what do u use ??
    R600a's Avatar
    R600a is offline Professional Member*/Membership Committee
    Jul 2019
    Hanging out with the mice behind the fridge talking bad about the roaches in the oven.
    It depends on the age condition and type of furnace.
    Sent from the Okie state usin Tapatalk
    "Is this before or after you fired the parts cannon at it?" - senior tech
    I'm tired of these mediocre "semi flammable" refrigerants. If we're going to do it let's do it right.
    Unless we change direction we are likely to end up where we are going.
    "It's not new, it's better than new!" Maru.
    Nov 2020
    Denver, Colorado
    Unless it's a newer install, it's easy enough, so why not?
    R600a's Avatar
    Jul 2019
    I like to on 90% ers on the lower ports because i have had problems with them clogging. On 80% i have never seen that.
    On a 90% i also like to hook a shop vac to the drain and sometimes even pull the inducer and dump water in that opening while the vacuum is sucking on the drain.
  5. Likes jconaway53 liked this post.
  6. #5
    Jul 2013
    Richmond, VA
    I keep a piece of solid copper wire in my bag. Find plenty of them in attics where sparky trimmed the wiring. A very small drill bit works too.
  7. #6
    Mar 2016
    Dayton Oh
    All, please elaborate on this. This is not something I have done but willing to add. What’s the science and reasoning behind this process.
  8. #7
    Quote Originally Posted by jbhenergy View Post
    once in a while you will come across a unit with a code "pressure switch stuck open"
    and you think , awe dam the switch is bad
    the little nipple where the hose connects on the inducer gets clogged
  9. #8
    Nov 2008
    Piney Flats, Tn.
    I see it on 80% more than 90's. And I use an allen wrench you know the little one for the gas valves.
  10. #9
    Nov 2020
    Denver, Colorado
    I typically just use a piece of Silfoss, seems to work great for me.
  11. Likes COOLJIM liked this post.
  12. #10
    Nov 2020
    Planet Earth
    Yes, if you are going in for a furnace cleaning, there's every reason you should clean the pressure switch holes too. Many a times, you will find them clogged to different degrees.
  13. Likes YOUNG FROSTY liked this post.
  14. #11
    Mar 2014
    Both pressure switch akde and collector and vendor side?
    Quote Originally Posted by Kris81 View Post
  15. #12
    Nov 2020
    Illinois
    I also use a small Allen wrench have seen both 90s and 80s clog. Typically the 80s where the nipple comes off the inducer housing will clog with rust or debris
  16. Likes theoldscroll, beenthere liked this post.
  17. #13
    Poodle Head Mikey's Avatar
    Poodle Head Mikey is online now Membership Chair/ARP Committee / Professional Member*
    I try to stay as far away from myself as I can.
    I always did.
    I use a 'just fits' drill bit and turn it clock-wise with my fingers as it goes in and out. So I can see if it actually collects anything.
    I like to blow out all the hoses as well. While I have them off I inspect for signs of the rubber cracking.
    PHM
    Quote Originally Posted by wantboost View Post
    PHM
    When faced with the choice between changing one's mind, and proving that there is no need to do so, most tend to get busy on the proof.
  18. Likes R600a liked this post.
  19. #14
    Mar 2018
    Kansas Flatlands
    I also like to check that tiny weep hole in the pressure switch itself and clear it out if obstructed with dust,etc. I use a broach for that. I was told long ago that was the reason for PS failures that moisture would get trapped inside and needed to "vent". Don't seem to see as many failures the past few years, as was 10-12 yrs ago.
+ Reply to Thread
Quick Reply Quick Reply
Register Now
Log-in
  • You may post new threads
  • You may post replies
