Results 1 to 10 of 10
Thread: Not Installed Correctly? Bryant Evolution 986T
    Oct 2020
    Confused Not Installed Correctly? Bryant Evolution 986T
    I'm not sure I trust my installer... He installed a new Bryant Evolution 986T 80K BTU dual zone furnace installed (2 stage heat with variable fan + AC condenser). He replaced our original 2 wires to the Nest Thermostats with 4 wires.
    - Then when the AC was on, the fan pumped cold air - fan is clearly on high - like level 10.
    - But when the HEAT was on, the fan is always very low - like level 2. The fan never kicks on into high gear.
    I told him this and he did some research and found out that he needed to run 8 wires instead of 4 - so stage 2 would kick in. So he re-ran the wires.
    Now we have the same issue. The only difference is that now the NEST Thermostats says "STAGE 2" when the heat is on, but the fan is the same low level. I would think that if it's 50 degrees out and we turn the thermostat up to 80, it would take a while, but eventually the fan would start to blast heat. I called Bryant but they told me I had to talk to him. But to be honest, I'm not sure if he has installed an Evolution before...
    Am I correct? Crazy? Wrong expectation? Do I need to call him back to adjust the dip switches and settings?
    SE Ohio
    Nest sucks. It's a shiny piece of junk that overcomplicates a simple task.
    AFAIK, the Evolution is a communicating system. All those nice features you paid for only are available with the thermostat that is designed for it.
    Southold, NY
    The fact the contractor would agree to hook up the N E S T POS is reason enough to be concerned.......Be very concerned!
    Philadelphia, PA
    You paid for a night end Evolution furnace and crippled it with a Nest?
    Oct 2020
    Apparently! Argh. I now see that the NEST can't control the Bryant Evolution Variable Speed Fan! How frustrating. Questions:
    - Since I have a two zone system, do I have to get two of the Bryant Evolution Connexx Controllers? Or can I use one for the main house and a Nest for the second zone (office)?
    - We only have the Evolution Furnace and AC unit. We don't have the humidifier, ventilator nor purifier. So it appears the only thing the Evolution ads for me is the variable fan speed - correct?
    - Do I have to order the Bryant Evolution Connexx Controllers and have them installed by my current installer (who I don't trust). Or is this something I can order and install myself / another installer?
    Just trying to figure out if I can save a bit of money here as we already way over budget! Thanks!
    Philadelphia, PA
    If it is a zoned system you will need to use Evolution zoning. Dampers, control panel, one Connex controller and a zone sensor or Smart Sensor. You can hire any Bryant or Carrier dealer to supply and install the system. Would be a good time to have install inspected and system setup verified.
    Benefits are full control of staging, variable speed fan, and enhanced dehumidification control.
    What area of the country are you in?
    Oct 2020
    Thanks! We are in California near the coast. So pretty mild winters and summers. Sounds like we over-bought the system (and under bought the controllers!) But my wife is very sensitive to noise so I thought getting a variable speed fan would help her sleep at night...
    See what the zone panel is? Did he really use an Evolution panel or one that doesn't communicate with the Bryant equipment?
    Oct 2020
    I see a Honeywell HZ322 panel attached to the furnace... Is that what you mean?
    You paid for and got a Maserati but turned it into a Yugo!
    Your contractor, and whomever configured this equipment package, has ZERO clue what he is doing.
Quick Reply Quick Reply
Register Now
Log-in
  • You may post new threads
  • You may post replies
