Results 1 to 20 of 20
Thread: 134A HVACR versus 134A Automotive.....Difference??
    May 2019
    Is there a difference between what the Auto people use and the type I have??
    Some additive in the Auto type??
    Jul 2019
    Oklahoma home its in the name
    Quote Originally Posted by RLJN View Post
    Some of the automotive stuff has pag oil and other junk in it.
    Sent from the Okie state usin Tapatalk
    Sep 2020
    I have seen a large difference in pressures you are looking for due to temperature demand of unit. I did a beer cooler with a target temp of 36 degrees, these are largely different pressures than youll see in automotive which has a max desired temp of 60 degrees. See your PT chart. Hope this helps
    Sep 2020
    But, 134A is 134A, auto tends to be more contaminated due to application, but yes it is the same refrigerant
    Mar 2018
    Virginia
    134a is 134a...it's the name of a particular molecule so it is what it is. Now that being said if you are buying small cans of auto 134a it may have an additive like leak sealer but if it does it will say that on the can.
    "I think Quantum tunneling would work great... "
    "Call a technician for God's sake. Or we'll see you on the news or the Dark Side of the Moon."
  6. Likes R600a liked this post.
  7. #6
    Apr 2003
    Maple Grove, MN
    Quote Originally Posted by Chris Stritchko View Post
    I have seen a large difference in pressures you are looking for due to temperature demand of unit. I did a beer cooler with a target temp of 36 degrees, these are largely different pressures than you’ll see in automotive which has a max desired temp of 60 degrees. See your PT chart. Hope this helps
    What? I admittedly don't know anything about MVAC, but I know that there's no "max desired temp of 60 degrees". Most automotive refrigeration compressors are designed to operate in the winter when in "windshield defrost" mode. What does your PT chart say then? Also, automobile air conditioning is made to be grossly oversized in order to cool the vehicle down from 130F or whatever it might start with. If you were to subject your beer cooler to the same conditions, I.E. start them both up when the inside temperature is 80 for example, I would think the pressures would be pretty close to the same.
    Just like how walk-in coolers and freezers that use R404A would be. On startup, the pressures would be almost identical as the boxes drop in temperature. It's just that the freezer is allowed to get lower.
    Whatever.
    If at First You Don't Succeed, Skydiving Is Not for You.
  8. Likes JayMan7 liked this post.
  9. #7
    May 2019
    So is it the consensus that 134A HVACR would work fine in Auto use,.....
    but the reverse is not recommended?
    The HVACR gas would have less containments and if oil is needed for auto use it can be added in the field.
  10. #8
    Jul 2019
    As long as you buy just refrigerant it doesn't matter. My hvac supplier has a pile of r134a jugs and half are labeled automotive but the only difference is the ones labeled ACR have an adapter to 1/4 flare.
  11. #9
    Mar 2018
    Virginia
    Quote Originally Posted by R600a View Post
    I hate that stupid automotive goofy ass acme fitting... Why did they do that crap?
  12. Likes R600a liked this post.
  13. #10
    Virginia
    I buy 30lb jugs of MVAC and HVAC , it just depends on where I happen to be in town when I need it fast , same stuff my friend , just buy the adapter
    But ... if you buy those little ass 12oz cans , some have leak sealer , and oil , and dye , but they do sell those with pure 134 as well, you have to read the label
  14. Likes R600a, JayMan7 liked this post.
  15. #11
    Virginia
    Quote Originally Posted by ammoniadog View Post
    What? I admittedly don't know anything about MVAC, but I know that there's no "max desired temp of 60 degrees". automobile air conditioning is made to be grossly oversized in order to cool the vehicle down from 130F or whatever it might start with
    I've checked vent temps while cruising and its usually 36-40 deg air blowing out , and im not using a stupid IR gun , I stick a probe in there
    So yeah its definitely oversized compared to the 55 deg from a home
  16. #12
    Sep 2014
    central IL
    the only differnce is auto will have a 5/16 flare on jug
  17. #13
    Mar 2018
    Virginia
    Quote Originally Posted by coolen63 View Post
    5/16 flare is on some minisplits. That goofy auto fitting is called a 1/2 acme.
  18. #14
    Jul 2002
    Chariton, Iowa
    Quote Originally Posted by JayMan7 View Post
    It was an attempt to stop people from using their R12 gauges and other stuff on R134a systems. R12 cars used mostly 1/4 flare service ports just like stationary stuff, with some exceptions like some having a 3/16 flare high side port. Remember supposedly chlorinated refrigerants will break down and destroy PAG oil, but the page that had a demo using a clear cylinder to show the oil turning black seems to have disappeared.
  19. #15
    Southold, NY
    R-134A for Automotive can contain higher levels of Moisture then R-134A meeting ASHRAE Standards!
  20. Likes mixsit liked this post.
  21. #16
    Mar 2018
    Virginia
    Quote Originally Posted by danielthechskid View Post
    That was my understanding as well but it's like why do that? I mean 1/4 flares were not changed in hvac/r so why change them in auto? And why such a dumb fitting? They could have at least done 5/16 flare.
  22. #17
    Oct 2011
    Chicagoland Area
    134a is 134a. The additives in the small cans are not compatible with refrigeration systems.
    Why is it that those who complain the most contribute the least?
    MONEY CAN'T BUY HAPPINESS. POVERTY CAN'T BUY ANYTHING
  23. #18
    May 2019
    So after reviewing all the input, my conclusion is that my HVACR 134A would be fine in my car systems....mechanic gets XX per pound here...5-6 times my cost.
    But he has a lot invested in AC equipment....I should not whine....but makes me realize that I sell R-22 too cheap.
  24. Likes R600a, pecmsg liked this post.
  25. #19
    Oct 2008
    ALSO, before R134a became the norm, I remember that the two differently sized flare fittings on R12 systems was meant to keep automotive DIYers from connecting that little 14 oz can to the high side.
    I guess some folks did that and the can blew up due to too high of a pressure, so they dummy proofed it.
    AND...yes, "unadulterated" R134a from the auto parts section is the same stuff that we get in the bigger bottles. Otherwise, it'd be called something else.
    "You never know what others don't know." -
    If I can't laugh at myself...then I'll laugh at YOU! -
  26. #20
    Jan 2015
    San Diego, CA
    Same stuff. Also it's 134a not 134A. There is a difference.
  27. Likes BALloyd liked this post.
