Results 1 to 12 of 12
Thread: factory supplied drain traps?
    Sep 2020
    I have a service company for one of the furnaces in our local library. The condensate line was damaged during a remodel and the supplied trap from Lenox that was mounted to the side of the furnace was destroyed. (below is the type originally installed).
    The service company wants to just use standard pvc fittings to make the trap. They assured me that it makes no difference and in fact theres will be better quality (and cheaper!).
    Is it acceptable to fashion a trap out of fittings instead of using the factory supplied trap?
    Southold, NY
    So whos accepting the liability if something goes wrong, Lenox didn't authorize that repair?
    Sep 2020
    The service company stands behind there work... just like you do.
    If the new p-trap is configured like the Lenox installation instructions show in regards to length, the addition of a vent etc... does it matter what material is used? Is there something special about the design of those traps?
    Southold, NY
    Quote Originally Posted by jimmydu View Post
    Yes it was designed that way and the UL sticker was assigned to that design. No once its changed Lenox is no longer responsible it something goes wrong and people get hurt.
    Make them buy the factory part and keep it original!
    Sep 2020
    but from a functionality standpoint I bet it makes little difference.. you know that too.
    Southold, NY
    You asked a question
    in a house, Appomattox, Va.
    I've had to make a trap on one, just made it the same depth as oem. what are you going to do when that rubber cap dryrots and starts to leak?
    Col 3:23
    Sep 2015
    Ontari-ari-ari-o
    PVC fittings do the same functional thing but once you modify any part of the original furnace it's no longer certified. The kits are cheap to just buy from Lennox do it properly and cover your ass.
    May 2020
    Haskell Oklahoma
    Unless It was under warranty, why would Lennox need to authorize it? How could a pvc trap make something go wrong?
    Cincinnati, Oh
    Quote Originally Posted by Hurst11 View Post
    What's inside the trap?
    Cincinnati, Oh
    Why do people come here to ask a question for which they already have the answer they want?
    Could be fine. May not be.
    This is a government building?
    Southold, NY
    Quote Originally Posted by hvacvegas View Post
    Exactly
