Results 1 to 16 of 16
Thread: 3 Story townhouse
    Sep 2020
    3 Story townhouse
    We have a project for new 3 story townhomes with flat roof and basement. Gas is available.
    What would you say is the best system to go with in this case?
    Southold, NY
    Quote Originally Posted by S_Kelly View Post
    Properly sized and installed.
    3 stories 3 system
    SW FL
    Climate Zone is ___ ___ ?
    What would you say is the best system to go with in this case? Thanks
    Equipment room on FIRST Floor?
    Architectural drawings are necessary in order to make sense
    of what Your 3 STORY TOWNHOUSE Is
    regarding the layout/ floor area.
    The actual heating and/or cooling needs can systematically be defined for your locale.
    _______________________ ___ _______ _ Figure 1 _
    Perimeter: Width - __ feet/ Depth - __ feet
    I presume the project is in the U.S.
    _______ ZIP _ _ _ _ _
    Gmail address: racingdan11
    www.mysimplifiedhvac.com
    Ventilation : ASHRAE 62.2, 2013
    https://www.thehouseplanshop.com/050m-0008.php
    Designer Dan __ It's Not Rocket Science, But It is SCIENCE with Some Art. _ _ KEEP IT SIMPLE & SINCERE ___ __ www.mysimplifiedhvac.com ___ __ Define the Building Envelope & Perform a Detailed Load Calc: It's ALL About Windows & Make-up Air Requirements. Know Your Equipment Capabilities
    Mar 2018
    Virginia
    "Best" can mean so many different things...
    Best cost?
    Best quality?
    Best efficiency?
    You haven't provided any important details whatsoever.
    For such a big project it seems like you would have the GC, via subs, making those decisions as part of the overall construction bid, and mostly they focus on keeping the cost down.
    "I think Quantum tunneling would work great... "
    "Call a technician for God's sake. Or we'll see you on the news or the Dark Side of the Moon."
    Oct 2014
    Saint Pail, Minnesota
    I’m going to reference your previous post regarding a 3 story townhouse.
    https://hvac-talk.com/vbb/showthread...TU-replacement
    Your best bet is to have a properly designed system, proper load calculations performed, proper ductwork design, and proper commissioning of each system. Air balancing is crucial in multi-story homes.
    In theory a three ton package unit Should perform the same as a 3 ton split system. It all comes down to who ever is purchasing the equipment.
    Southold, NY
    Quote Originally Posted by Pnasty View Post
    In theory a three ton package unit Should perform the same as a 3 ton split system. It all comes down to who ever is purchasing, sizing, designing and installing the equipment.
    Fixed
  7. Likes kdean1 liked this post.
  8. #7
    Oct 2014
    Fixed
    OP wants the easiest answer, not willing to put in work of providing details or any response.
  9. #8
    Oct 2011
    Culver, Oregon (Central OR)
    He wants to hear it costs 500 dollars. Uncle Ben will change the filter.
  10. #9
    SW FL
    https://www.energystar.gov/ia/home_i...ors/qispec.pdf
    Buildings should be designed to IECC 2018 +
    MODULAR construction +
    State Building Codes.
    https://codes.iccsafe.org/content/do...te_type=public
  11. #10
    Sep 2020
    Thanks for the responses, I appreciate it.
    As far as details, these townhomes are about 1,000 sq.ft. per floor, 3 floors, so 3,000 total sq.ft.
    They have a basement and flat roofs.
    I know detailed load calcs. need to be done.
    I was wondering more in general whether the standard would be to put in a RTU with 3 zones, 1 zone per floor with zone dampers and some kind of bleed off to other zones. Similarly, if a split system was installed.. would you put in the air handler in a certain floor and provide similar zone control or 1 air handler/ 1 condenser per floor.
    Thanks again, I appreciate it
  12. #11
    Oct 2014
    With that amount of floor space on each level i would say 3 split systems would work best for comfort. Zoned systems definitively require someone that is experienced with them.
    In any case, if one single system (zoned or not) is installed, ductwork has to be perfect to provide comfort across all levels. It doesn’t really matter if you use a package unit on the roof or a split system with a furnace in the basement. There’s package units on top of buildings 5 stories high that pump air down to the first floor and air handlers in basement that pump air up 4 stories. Ductwork design is crucial.
  13. #12
    Oct 2011
    Vrf system for real zoned heating/cooling.
  14. #13
    SW FL
    Similarly, if a split system was installed ..
    How many RTU's could possibly exist or be used in residences/ 3-story townhouses ?
    ___ How many 3-story townhouses have a FLAT roof?
    ____________ 2-Story + Basement (underground)
    ___ How many 3-story townhouse are large enough to warrant a separate HVAC system on each floor ?
    __ ~ 1 out of 40,000+ residences / LARGE, 2-story + basement WITH Flat roof.
    __ .:. HVAC personnel may come upon this specific situation less than once a decade.
    __ THERE IS NO STANDARD for Unique Buildings.
    ______ .. CUSTOM DESIGN.
  15. #14
    SW FL
    There are package units on top of buildings 5 stories high that pump air down to the first floor and air handlers in basement that pump air up 4 stories. Ductwork design is crucial.
    + the RTU's just might have 5, 10 or 15 HP motors on the blowers
    that are capable of providing upto 2" ESP.
    ... NOT the 1/2, 3/4 or 1 HP found in more conventional 3 to 5-ton set-ups.
  16. #15
    Atlanta GA area
    To the OP...
    Might want to read my signature paragraph...
    The key to your issue is within the couple of sentences...
    Sorry... however doing it correctly, so it works properly...
    Will be the expensive way.
    Now if you want a compromise that costs less... there will be compromises in the comfort from level to level.
    Your choice...
    GA-HVAC-Tech
    GA's basic rules of home heating and AC upgrades:
    *Installation is more important than the brand of equipment
    *The duct system keeps the house comfortable; the equipment only heats and cools (and dehumidifies)
    *The value of comfort, over the long term; leave economic choices behind!
    Choose your contractor wisely!
  17. #16
    Oct 2014
    Quote Originally Posted by dan sw fl View Post
    True I didn’t think about that.
