Results 1 to 20 of 48
Thread: Inducer is full - now what ?
    This is a job done remotely over a 1200 mile distance - my instructions / someone else's hands.
    120K Goodman up flow natural gas furnace. Complaint was: no heat. Inducer motor very hot and turning very slowly. Inducer replacement process revealed the original inducer housing full of water - well; as full as possible. <g>
    Picturing this furnace: it seems to me that either the collector box filled to overflowing-into-the-inducer (which seems impossible: pressure safeties and so forth) - or; the water came in via the exhaust venting.
    Can anyone here think of an alternate way which would produce the water logged inducer housing?
    PHM
    Socialism is a zombie. It never dies - even though it is constantly decaying and decomposing.
    Feb 2018
    Bay Area, Ca
    I have had similar issues when the trap was not primed. It was a cheap P.O.S. though.
    Sent from my SM-N960U using Tapatalk
    What trap?
    The evap. trap?
    If so; how would that fill the inducer?
    PHM
    Quote Originally Posted by Zamoramax View Post
    PHM
    Mar 2015
    Medford, N.Y.
    Is this the style w/ the drain trap in a drain line from the inducer blower housing? The trap gets plugged and vinegar cleaned up the trap. You fill the trap w/ vinegar ,cover the holes and shake shake shake,dump,repeat until no more crap comes out.
    Feb 2018
    Bay Area, Ca
    What trap?
    The evap. trap?
    PHM
    I am assuming that the install was a 90% or greater? The collection trap for the condensate.
    The way you questioned that I am now to assume its an 80%er?
    Feb 2018
    Bay Area, Ca
    Also if its a 90%er or better if its not pitched the right way you could create the same issue. Carrier made products ask you to pitch the unit Ό" forward not level.
    Virginia
    Throw us a bone here - is this a 80% or 90% furnace. Better yet, please provide the model and serial number.
    This attachment will help with vent water issues.
    Name:  Eric - Goodman - IMG_2153.jpeg
    It looks like this pic.
    Quote Originally Posted by TechmanTerry View Post
    PHM
    96% I think. I just couldn't picture any trap which would drain the bottom of the inducer housing. That's why I asked: "what trap?" <g>
    PHM
    Feb 2018
    Bay Area, Ca
    Granted I have a carrier but this is the trap on mine. Thats it just behind the electrical.
    Attachment 818826
    OH! Sorry; I didn't think I had the M&S #'s - but I came across a picture while looking for the one I just posted.
    PHM
    Virginia
    That attachment does not appear to work (at least on my computer). Can you just type in the model and serial numbers?
    GMVC961205DNAA
    14082227
    Quote Originally Posted by rundawg View Post
    PHM
  14. #14
    Mar 2018
    Virginia
    Some units like Trane have an inducer drain. So was there a drain line on this inducer that was clogged up?
    "I think Quantum tunneling would work great... "
    "Call a technician for God's sake. Or we'll see you on the news or the Dark Side of the Moon."
  15. #15
    See the small hose on the right under the exhaust ell. Sometimes they clog, and then the water drains to the inducer.
  16. #16
    May 2015
    New Orleans, LA
    Since this is a condensing furnace perhaps either the drain line out of the blower section was never installed? or clogged more likely.
    That would cause the normal flue / combustion process condensate to back up into draft inducer.
  17. #17
    Virginia
    GMVC961205DNAA
    14082227
    I don’t see any bulletins on venting issues for this furnace, so I have to go with one of two scenarios:
    1. Incorrect installation of the furnace (see attached installation manual).
    2. This is a short flue (vent pipe) scenario. Inducers operating with short flues, can cause a vapor lock on the condensate drain because they are moving too much air, which causes water to back up until the system shuts down.
  18. Likes Zamoramax, ksefan, VTP99 liked this post.
  19. #18
    Where is the drain and trap?
    I think I see a lot of rust on the left side deck, from what?
  20. #19
    I don't know - I'll make some inquiries tomorrow.
    Quote Originally Posted by pacnw View Post
    PHM
  21. #20
    Cincinnati, Oh
    Drains are plugged, or no vent after the internal trap that hangs in the blower compartment.
    See that rust on the left side?
    That indicates that the collector box hasn't been draining. The collector box gasket designed for light duty condensate, not being flooded by a plugged trap.
    https://hvacdist.com/psr-01-collector-box-pressure-switch-relocation-kit-now-available/
    Is a somewhat related bulletin, and discusses proper drainage for this unit.
