Guardian... may as well be Goodman. Round these parts if its a hacked install there's a more than good chance its a goodman(cheap=more money). We have been seeing alot of Guardian popping up that I could assume was installed by the same Goodman installers...as for the furnace in question. I would probably replace it. I have a few pic's to go by and a mild description. At what point will the parts and labor overrun the new install?
Sent from my SM-N960U using Tapatalk
Originally Posted by
Zamoramax
Exactly.
I will have to bring the boss back to make a decision on it but my inclination is change it out. They didn't do anything right. It isn't even inspected.
Sent from the Okie state usin Tapatalk
"Is this before or after you fired the parts cannon at it?" - senior tech
I'm tired of these mediocre "semi flammable" refrigerants. If we're going to do it let's do it right.
Unless we change direction we are likely to end up where we are going.
"It's not new, it's better than new!" Maru.
Post Likes - 1 Likes, 0 Dislikes
Yep. That's the local brand around here for side jobs and handymen because the supplier will sell them over the counter to anybody without requiring an account or even a gas license. They aren't bad units either I had one in my basement before a flood took it out and I replaced it with a Rheem.
Inducer and heat exchanger cost + labor should get you in the neighborhood of new furnace $$$.
R600a
I sent the boss's son back to make the decision on this and he decided it needed a new vent pipe and inducer motor. Well I don't agree with him it's not my license on the line. So I pulled out the old vent pipe and discovered this. AmeriVent to duravent obviously doesn't hold together very well so just add screws.
I'm pretty sure they went into this job with the thought of let's see how many rules we can break on one install.
Did those screws actually puncture the inner liner? I’m pretty sure you can screw into B-vent but you need to use the 1/4” screws so it won’t puncture or contact the aluminum.
Quickly, I must hurry, for there go my people and I am their leader!
thatguy
I don't know but you can't connect two different brands without using a slip connection.
R600a
They probably thought it was cause the damn thing kept slippin out!
