Results 1 to 20 of 37
Thread: 3 ton Heat Pump system Install with custom Airbox
    Sep 2020
    Maryland
    3 ton Rheem Heat Pump system with 15kW heat strip install.
    Had to custom built the airbox with air filter cabinet.
    Please let me know what you think.
    Jan 2012
    Missouri, USA
    Looks good, might pull the cap off the secondary side of the EZ Trap. Maybe some better pipe support than bricks.
  3. Likes UltraCool liked this post.
  4. #3
    Sep 2020
    Maryland
    Thanks.
    It is on a slope. I happened to see some bricks laying around; what would you suggest, filling up with dirt?
  5. #4
    Jan 2012
    Missouri, USA
Size:  239.2 KBName:  5042E854-0C3C-4AB1-9F69-111E6813A227.png
    Quote Originally Posted by UltraCool View Post
    Thanks.
  6. #5
    R600a's Avatar
    R600a is offline Professional Member*/Membership Committee
    Jul 2019
    Hanging out with the mice behind the fridge talking bad about the roaches in the oven.
    Nice! How does the filter door stay close?
    Sent from the Okie state usin Tapatalk
    "Is this before or after you fired the parts cannon at it?" - senior tech
    I'm tired of these mediocre "semi flammable" refrigerants. If we're going to do it let's do it right.
    Unless we change direction we are likely to end up where we are going.
    "It's not new, it's better than new!" Maru.
  7. #6
    Sep 2020
    Maryland
    Thanks. I'm not sure how to use them. If you have an example picture that would be helpful.
  8. #7
    Sep 2020
    Maryland
    I could not find an applicable latch, ending up made some from sheet metal.
    Here is a picture of the airbox.
  9. #8
    Jan 2012
    Missouri, USA
    I wish they made those with radius corners.
  10. #9
    R600a's Avatar
    Jul 2019
    Nice. Don't forget to remove the packaging on the filter.
  11. #10
    R600a's Avatar
    Jul 2019
    A couple things I would do different is the line set and conduit would have to be anchored to the wall. I usually use metal single hole clamps for the conduit and metal double hole clamps for the line set.
    Also if possible move the pad closer to where the line set comes out of the wall.
  12. Likes ksefan, UltraCool liked this post.
  13. #11
    Sep 2020
    Maryland
    Thanks for your comments,
    I'll anchor the conduit the next time I come in for a PM.
    The line set is quite a few inches from the wall so I guess I'll just leave it.
    I'll keep your advice in mind on my next job.
    I had a hard time brazing at the suction service valve. I went through 2 of them before realizing that I have to come in perfectly straight, otherwise as soon as I heat up the joint, the sideway pressure from the pipe would deform/damage the brazing cup. I'd blame it on the Chinese made valve with too thin and soft copper. Attached is the first one that I messed up
  14. #12
    Jan 2010
    Sea to Sky
    I like your custom metal work. The lineset outside needs some more pride in your workmanship. Not sure why you didn't turn 90 degrees coming out of the wall and run the line set neatly along the wall. It could have then been supported an secured properly. I probably would have convinced the customer to go with some line hide in this case.
    Sent from my SM-G965W using Tapatalk
  15. #13
    Sep 2020
    Maryland
    Yes, good comment,
    I would move the condenser closer to the hole too, but that would require removing the tree stump and leveling the ground.
  16. #14
    R600a's Avatar
    Jul 2019
    A good bender with the reverse attachment would help you make it neat and not have tension on the valves. I am currently using the CPS Black Max and I like it pretty well but the hilmor is way better.
  17. #15
    Sep 2020
    Maryland
    Thanks for your comments.
    I'll keep those in mind on my next jobs.
    So to do that I'd have to add 2 more 90deg elbows, one to turn toward the wall and another to turn along the wall, right?
  18. #16
    R600a's Avatar
    Jul 2019
    I would bend 2 90s and a 45 to bring it into the condenser at the right angle.
  19. Likes UltraCool liked this post.
  20. #17
    Sep 2020
    Maryland
    I do own a CPS Back Max and made those bends with it, except for the 90deg elbow coming out from the wall.
    It seems to produce excessive ribs when you get close to 90deg.
  21. #18
    Sep 2020
    Maryland
    Ok, thanks.
    I was in the mindset of minimizing bends and joints.
  22. #19
    R600a's Avatar
    Jul 2019
    Try lubricating the dies and if that doesn't work then you probably need better copper.
  23. #20
    R600a's Avatar
    Jul 2019
    Ok, thanks.
    I will often add a joint between the 90s if I mess up on the distance between them on the first try. I get better at it every time.
Quick Reply Quick Reply
Register Now
Log-in
Tags for this Thread
  • You may post new threads
  • You may post replies
