+ Reply to Thread
Results 1 to 20 of 28
Thread: Carrier Installation
    Jul 2020
    Tampa, FL
    Doubt that the float switch will work as intended. Also looks like someone forgot something when installing the air handler...
    I talked to one of the installers as he was getting ready to finish up on another home in the development. He was hooking up his vacuum pump so I casually asked him if he had to get down to 500 microns and his answer was "no, we just go down to 30-in or so because this is a new system". Yikes!
Size:  37.5 KBName:  20200426_095328.jpg
    Northern Calif
    How does that non-trap pass the building inspection? Is there no duct testing for new homes?
    I'm not young enough, to know everything...
    Jul 2020
    Tampa, FL
    Quote Originally Posted by dieseldude View Post
    I wondered about that myself but then I realized that the run itself is the "trap" because it is routed down and under the slab and then back up above ground outside.
    Jul 2013
    Richmond, VA
    Is this Florida? Don’t they put their traps outside?
    Jul 2020
    Tampa, FL
    Quote Originally Posted by CircusEnvy View Post
    Yes, Florida - forgot to mention that little tidbit. Below is a sketch of the run with the trap partially inside and partially outside.
    Virginia
    That trap oughtta catch something ....
  7. Likes captube liked this post.
  8. #7
    Jul 2013
    Richmond, VA
    Quote Originally Posted by bdserv View Post
    6-8 years that drain line will be unusable. How is that even code???
  9. #8
    Virginia
    You know whats really odd , I just thought of something ... the P trap in My home has never clogged. I've never had to touch it
    Goodman HP
  10. #9
    Jul 2013
    Richmond, VA
    Quote Originally Posted by Snapperhead View Post
    Goodman HP
    Mine neither. Drain pan has cracked before, but never a stopped up drain and I never cleaned it out. Funny how that works.
  11. #10
    I’m in Florida, 90% of the drains are run like that. They usually work, but it can be challenging.
  12. Likes baby b liked this post.
  13. #11
    SE Ohio
    Goodman HP
    What air filters do you use? Filter grilles or rack at the furnace?
  14. #12
    New Jersey
    In my area, new construction is paying by piece work. No nitrogen, no checking pressures or temperatures, just how many units can be installed in one day.
    Sent from my ASUS_P00J using Tapatalk
  15. Likes ga-hvac-tech, bdserv liked this post.
  16. #13
    Virginia
    Quote Originally Posted by kdean1 View Post
    I have the 14x20x1 in the AH , merv 8 , change it every few months , or 6 months if I forget
  17. #14
    Quote Originally Posted by chander View Post
    Same here...
    Nobody I know...
    Uses N2 to braze...
    And very few even have a vacuum pump on the job...
    Just blow it out with 410...
    GA-HVAC-Tech
    GA's basic rules of home heating and AC upgrades:
    *Installation is more important than the brand of equipment
    *The duct system keeps the house comfortable; the equipment only heats and cools (and dehumidifies)
    *The value of comfort, over the long term; leave economic choices behind!
    Choose your contractor wisely!
  18. #15
    Northern Calif
    Quote Originally Posted by ga-hvac-tech View Post
    Same here...
    Nobody I know...
    Uses N2 to braze...
    Sounds like guarantied future work....
  19. Likes R600a, ga-hvac-tech liked this post.
  20. #16
    Mar 2016
    Dayton Oh
    Same here...
    Nobody I know...
    Uses N2 to braze...
    Your kidding about the vacuum pump right?
    Like that’s not even possible in my opinion
  21. Likes R600a liked this post.
  22. #17
    Same here...
    Nobody I know...
    Uses N2 to braze...
    I need to clarify this...
    I was referring to new construction... sorry for not noting that.
    In new construction... it is all piece-pay...
    And very little follow up...
    Unless something goes seriously wrong!
    GA-HVAC-Tech
  23. #18
    Jul 2020
    Tampa, FL
    It's such a disservice to the people who end up with these poorly installed systems though, and it gives the industry and the equipment manufacturer [where homeowners usually place the blame] a bad reputation in general.
    It's not uncommon to see the installer's service vehicles at homes less than a year or so old, sometimes making multiple visits to fix problems, and often running around with a torch...
  24. #19
    Aug 2009
    Beatrice, NE
    Yes but doesn't the quality of the house match the quality of the HVAC installation? Usually these get done fast and cheap builders are the worst quality. There was a house built in my area that the stairs coming off the deck behind the house were not even straight/didn't fit. They should have been an inch or two shorter to straighten them out, you could see it from the street. If there are things that obvious how much is hidden?
  25. Likes ga-hvac-tech liked this post.
  26. #20
    Granite countertops and black SS appliances sell a house...
    Few seems to care about quality...
    They want glitz and glamor...
    Then they learn the hard way...
    Yet they go back and do it again when they buy their next house.
    We as a society have flunked the prosperity test...
    We have lost consciousness of what value is...
    Sadly... history teaches us: re-learning the lesson, comes with pain.
    GA-HVAC-Tech
  27. Likes CHAINIK liked this post.
+ Reply to Thread
Quick Reply Quick Reply
Register Now
Log-in
  • You may post new threads
  • You may post replies
