+ Reply to Thread
Results 1 to 9 of 9
Thread: McQuay/Daikin Chiller pLan failure
    Sep 2020
    I’ve had a few of these and it takes some playing around to figure out which serial card or controller is actually causing the problem. I usually swap things around and see where the problem follows or stops. This time I am dealing with an intermittent failure and of course I am never on site when it happens. Anyone have a better method to diagnosing a pLan failure on a McQuay/Daikin chiller
    Apr 2020
    va
    model number?
    Jun 2008
    Windsor, Ont.
    Explain the pLan failure a little more. Is this an error message generated by windows on the touchscreen during boot up?
    Sep 2020
    It’s an AGS180C. Three Microtek II pCo 2 and 3 controllers. One unit controller (pCo2) and each compressor has its own controller, circuit 1 is a pCo2 and circuit 2 is a pCo3 . pLan failure shows up on the main controller as an alarm. I know it’s when it’s not seeing the other controllers on the network but it doesn’t specify which controller is the problem. Then you also don’t know is it the controller or the serial card.
    Florida
    have any of the controllers been changed out, possible firmware mis-match?
    Apr 2020
    va
    Software versions must match. May need update to later version. Check connectors between controllers.
    Apr 2020
    va
    1. Other Fixes and Changes
    pLAN NETWORK FAILURE
    Logic has been revised. Previous logic may have missed pLAN failures after initial power up. Revised logic will catch pLAN failures at power-up and throughout chiller operation.
    Code change in revision AGSD30101G, check for latest issued version.
    Apr 2020
    va
    pLAN Failure
    Alarm description (as shown on screen): pLAN Failure
    Trigger: No circuit controllers found on pLAN for 60 seconds
    Action Taken: Rapid stop all circuits
    Reset: This alarm can be cleared manually via the keypad, but only if at least one circuit is
    connected to pLAN.
    No external serial card. Last version code is 1H. All controllers MUST have same version code. 60 sec delay was added in later versions due to frequent faults.
    Sep 2020
    I am running 01H code currently on all the controllers. Updated it last week to try and correct the problem. I suppose ehsx is correct the serial cards only have comms to the benshaw starters. I’m guessing then it is the main controller because if it sees at least one circuit it’ll run.
    Jan 2021
    i have Mcquay WMC chiller.
    I purchase new display ( this is inbuilt with PC box).
    This new display is not having plan file .
    controller is having program of WMC3UU10K.
    can anyone give me its plan file.
    Thanks,
    Rahul Gunjal
+ Reply to Thread
Quick Reply Quick Reply
Register Now
Log-in
  • You may post new threads
  • You may post replies
