+ Reply to Thread
Page 3 of 3 FirstFirst 123
Results 41 to 59 of 59
Thread: Not all walkins are pump down
  1. #41
    Mar 2016
    NY
    CCH is still cheap insurance?
    Good point! So is a pump down imo.
    “Happiness can be found, even in the darkest of times, if one only remembers to turn on the light.”
    "Ha! Memory is RAM!"
  2. #42
    Southold, NY
    Quote Originally Posted by Bombboy90 View Post
    I was taught in school years ago one major benefit to walk in cooler pump down was to prevent refrigerant leakage during the off cycle if the evap has a leak from say, tomato or onion acid eating at the coil. I know most coils are coated but leaks find a way...
    Among the other points listed, I never really thought of it to prevent liquid slugging. Makes sense really, and also bbeerme makes a point, solenoid is off no liquid in the compressor, no reason for a CCH thus saving $
    The CCH is only good during the off cycle. While running the motor windings keep the oil warm.
  3. #43
    Apr 2003
    Maple Grove, MN
    Yeah, when its -20°F that CCH is a good thing to have
  4. #44
    Jan 2019
    EU
    Quote Originally Posted by TechmanTerry View Post
    Why is that?
    Installers don't have the knowledge, or perhaps they don't want to bother with pump-down set up.
  5. #45
    Austin, Texas
    So all yÂ’all did yo homework and found out a properly operating system without a pump down will not cause a flooded start, no slugging. In fact the tev will close on the off cycle. The tev will not feed in the off cycle! All the liquid refrigerant in the Evap will evaporate. As to migration in the cold parts of the world the crankcase heater takes care of that..
    And as to those 100 foot suction run at -20 ambient refer to the basis refrigerant textbooks and the pt chart how the vapor condenses to liquid. Tev are the most mis-understood component of the refrigeration system!
    FYI in the 45 years I have been working, the only time I found a busted crank was due to a defecting tev flooding. We always breakdown those semi hermetic for a Look see and a few hermetic compressors as well, just for fun.
  6. #46
    Southold, NY
    Quote Originally Posted by rickl View Post
    If that’s how you feel fine!
  7. Likes WT70 liked this post.
  8. #47
    Oct 2011
    Harrisburg, NC
    We do the same a lot of times, when we have time from all the service calls to tear it down.
    One busted crank in 45 years? Go buy yourself a lottery ticket.
    I can't fix it if it won't stay broke..
  9. #48
    Aug 2008
    Hibbing, MN
    Quote Originally Posted by BBeerme View Post
    Typo ?
    Bad grammar. I meant that migration of refrigerant is not possible if you’re pumped down.
    If God didn't want us to eat animals... He wouldn't have made them out of MEAT.
  10. #49
    Oct 2011
    Harrisburg, NC
    Directly from a Sporlan rep....
  11. #50
    May 2014
    Bay Area California
    Very rare to see a busted crank. I've probably never seen one.
    Most likely scenario is the clearance at either end of the connecting rod, piston/rings, or valves.
    I do a triple evac with nitro to remove non condensables.
  12. #51
    Oct 2011
    Harrisburg, NC
    Oil slugging on racks will tear a compressor up.
    Wait. Ha. Pistons and rods, I guess I’ve only had a crank bust when it hit the rod that came off when oil went thru the heads.
  13. #52
    May 2014
    Bay Area California
    Yeah, cranks do get severely damaged, but bust? Like in two pieces? VERY rare.
  14. #53
    Mar 2013
    Treasure coast, FL
    Quote Originally Posted by BadDaddy420 View Post
    Are you confusing evaporator pressure with inlet (liquid line) pressure??
    Sent from my Moto Z (2) using Tapatalk
  15. #54
    May 2014
    Bay Area California
    Have to get Remanworld to weigh in on this one, he's the authority here. Not sure I got his username correct.
  16. #55
    Oct 2011
    Harrisburg, NC
    Quote Originally Posted by shellkamp View Post
    Liquid pressure goes down in off cycle, suction would rise.
  17. #56
    Mar 2013
    Treasure coast, FL
    What are you trying to say???
    To be clear, all I said was that on non-balanced port valves, the inlet (liquid pressure) acts as an opening force on the valve. The difference in pressure between the liquid line and the outlet of the TXV will aggravate this condition.
  18. #57
    Oct 2011
    Harrisburg, NC
    Rickl stated “valve closes in off cycle”, which a lot said this doesn’t happen. So I wanted a true answer myself.
    I honestly thought the power element would overcome the spring, but it doesn’t.
    According to Sporlan Rep, the valve closes. I asked him because what better way to get the proper answer than ask the people that make the valves.
    The liquid pressure actually does push down on the metering needle, during operation it helps keep movement of the TEV smooth.
    Internal EQ valves uses the pressure on the outlet of the TEV for the pressure under the power element through an internal port. External uses the pressure from the suction line on the outlet of the evaporator.
    In off cycle, suction pressure rises, pushes against the power element, along with the spring to overcome power element force, closing the valve.
    That’s not to say it doesn’t fully close until pressures equalize, and worn out valves may bleed by, but a TEV closes on off cycle.
  19. #58
    Southold, NY
    Correct but that can take several minutes while the valve is still beating refrigerant into the evaporator. That refrigerant condenses into a liquid
    Depending on the operating conditions it could be a little or a lot
  20. #59
    Oct 2011
    Harrisburg, NC
    Exactly. But it does close. The time it takes to close throws most of us as we see the pressures equalize.
    I’m still a proponent of pump down. But on smaller systems and cap tube systems how often do we see that except for True equipment I think.
+ Reply to Thread
Quick Reply Quick Reply
Register Now
Log-in
  • You may post new threads
  • You may post replies
