+ Reply to Thread
Thread: Northstar flake ice
    Jun 2019
    Northstar flake ice
    What is the ideal salinity level to make the best ice?
    Mar 2015
    Medford, N.Y.
    Quote Originally Posted by polarey907 View Post
    What is this salty water/ice being used for?
    Jun 2019
    It is flake ice we use for keeping seafood (Pollock,salmon,halibut,cod)chilled during processing prior to going into the blast freezers and/or plate freezers
    Mar 2015
    Medford, N.Y.
    Doesn't the salinity depend on the available water source. Atlantic,Pacific, Salt Lake. Or are you making your own salt water?
    Jul 2000
    Guayaquil, EC
    Northstar recommends starting at 100-200 ppm and then adjust the feed rate of your salt feeder to get the best ice removal from the drum.
    AAEC840northstariceflakermanual.pdf
    Jun 2019
    We have a brine barrel that pumps salt brine to each ice maker.in the make-up water box we mix fresh city water with the brine.the brine line and water line going to the water box are controlled/metered with your typical ball valve.ive been doing refrigeration now for awhile but I'm fairly new to the ice making.i know salt effects the freezing point of water so I figured there is probably a ideal salinity level you would want in order to make the best ice.
    Thank you guys very much for taking the time to share your knowledge with me.very much appreciated.
+ Reply to Thread
Quick Reply Quick Reply
Register Now
Log-in
  • You may post new threads
  • You may post replies
