Results 1 to 6 of 6
Thread: Double flare
    Apr 2020
    va
    Double flare
    EPA mandated new equip mfgs to reduce or eliminate flares to reduce leaks and use double flares where required. Most went to flat face o-ring fittings.
    Do you use double flare tools?
    difficulty?
    opinions?
    Jul 2019
    Oklahoma home its in the name
    Quote Originally Posted by ehsx View Post
    difficulty?
    opinions?
    I started using double flare this year. I am still getting the hang of tool so it often takes me a couple of tries but it is totally worth it.
    Edit: since when did the EPA mandate no flares? I haven't seen any changes yet?
    Sent from the Okie state usin Tapatalk
    Apr 2020
    va
    2011 for equipment manufacturers, ASHRAE Standard 147
    Apr 2020
    Garner NC
    double flares have no better chance of working than single flare ones if its not done correctly to begin with... I'm a Car/Truck and Bike guy, done thousands of them...Done thousands of mini splits with single Flare, i also us the oil on mating surfaces..never any issues if you use the right tools with my torque tool that i always had for engine/transmission and axle rebuilding(and crow foot)and follow the Mfg recommendations....
  5. Likes R600a liked this post.
  6. #5
    Jul 2019
    Why haven't they switched yet?
  7. #6
    Mar 2016
    Dayton Oh
    That’s in the factory. I’m in the field.
    My flares are field supplied.....
