+ Reply to Thread
Page 3 of 16 FirstFirst 1234567891013 ... LastLast
Results 41 to 60 of 320
Thread: Micron Guage, which is the best buy?
  1. #41
    R600a's Avatar
    R600a is offline Professional Member*/Membership Committee
    Jul 2019
    Hanging out with the mice behind the fridge talking bad about the roaches in the oven.
    Quote Originally Posted by Sapote View Post
    Do you guys isolated the micron gauge before releasing the refrigerant to avoid contaminating?
    No. I try to keep the number of connections and valves as low as possible. I do try to keep the stem of the guage pointed up to keep oil from running into it.
    Sent from the Okie state usin Tapatalk
    "Is this before or after you fired the parts cannon at it?" - senior tech
    I'm tired of these mediocre "semi flammable" refrigerants. If we're going to do it let's do it right.
    Unless we change direction we are likely to end up where we are going.
    "It's not new, it's better than new!" Maru.
  2. #42
    On a bull named Foo Manchu
    No
  3. #43
    Aug 2020
    So California
    For those who don't isolate the micro gauge, how do you know if its displayed valve is correct? last time it was calibrated?
  4. #44
    R600a's Avatar
    Jul 2019
    You can calibrate the bluevac in the field. Also it has to be cleaned regularly.
  5. #45
    Aug 2020
    So California
    Quote Originally Posted by R600a View Post
    How do one know the ambient pressure in the field any where?
  6. #46
    Aug 2020
    So California
    IF you trust the CRT's ball valve, then why not isolating the micron gauge with one and forget about recalibrating and cleaning?
  7. #47
    R600a's Avatar
    Jul 2019
    Calibrating a micron gauge has nothing to do with pressure they are not a pressure sensing device.
  8. #48
    When the bluvac is out of calibration there is a indicator plus another indicator for oil fouling.
  9. Likes R600a liked this post.
  10. #49
    R600a's Avatar
    Jul 2019
    And of course go bluevac or go home.
  11. #50
    Aug 2020
    So California
    Very funny you, because I designed such a thing. Micron gauge using the principle of thermal conduction in the gas medium to determine the density of the gas, or the pressure of it given its temperature is known. There is a heater element and a thermocouples inside, and the computer chip doing all the calculation running a programming codes. Ask how do I know.
    Of course we calibrated the gauges in the factory using a know pressure for a particular gas.
    It's similar to the Mass Air sensor for metering the air intake in your modern fuel injected engines.
  12. #51
    May 2018
    I use a Bluvac, so isolating it is not mandatory, it can handle 500psi according to the specs. Having said that, I usually release the charge, or add charge, whichever the case may be, til the pressure is above atmosphere, say 15-50psi, stop, remove vacuum gauge, install cores, and finish charging.
  13. Likes joemach, Matt Woodbridge liked this post.
  14. #52
    Quote Originally Posted by channellxbob View Post
    500 psi is a old spec. New spec is 1000 psi.
  15. #53
    R600a's Avatar
    Jul 2019
    Now I'm curious. Since you're an engineer could you please look up bluvac calibration instructions? I would be really interested to hear your opinion on their method.
  16. #54
    Jul 2020
    San Diego, CA
    Of course, not due to contamination, but because positive pressure isn't good for micron gauges
    Sent from my SM-A516U using Tapatalk
  17. #55
    R600a's Avatar
    Jul 2019
    Quote Originally Posted by Matt Woodbridge View Post
    Especially if you use a Just Better at leaking micron gauge.
  18. Likes Matt Woodbridge, Zamoramax liked this post.
  19. #56
    1000 psi...
    Not really worried about overpressure.
  20. Likes Matt Woodbridge liked this post.
  21. #57
    Jul 2020
    San Diego, CA
    Lol, after my response, I read all your guys comments, on there actually good for i think someone mentioned 1000 psi. I wouldn't try it with my gauge, but just in case, I dont have to worry so much
  22. Likes R600a liked this post.
  23. #58
    Jul 2020
    San Diego, CA
    1000 psi...
    Yeah I just seen that, I've just never tried any positive pressure, ive always taken off my gauge.
  24. #59
    Aug 2020
    So California
    That's not too difficult, isn't it? This is the whole point I try to say in the other post about releasing refrigerant just enough higher than ambient pressure before installing the core valve, but people here think I'm nut.
  25. #60
    Aug 2020
    So California
    Just had a quick look at the micro BluVac user guide. It says:
    If oil or other contamination is inadvertently drawn into the sensor, the display will show:
    To clean the sensor:
    1. Turn the μBluVac+ power on.
    2. Shake out any excess oil.
    3. Using an eye dropper or syringe, fill the sensor port hole with isopropyl alcohol. Do not insert any object into the port.
    4. Shake out the alcohol.
    5. Repeat steps (3) and (4) three times.
    6. Thoroughly dry the sensor by pulling a vacuum for about 1 minute, or allow at least 1 hour to air dry.
    7. If OIL still shows on the display, perform a freezer calibration.
    Wow, with all the steps involved in cleaning, why not add an isolation valve?
  26. Likes Matt Woodbridge liked this post.
+ Reply to Thread
Quick Reply Quick Reply
Register Now
Log-in
  • You may post new threads
  • You may post replies
