Results 1 to 13 of 23
    May 2020
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Trane RTAC 275 will not start
    Got a problem with one of our chillers with these credentials:
    Type: RTAC 275,
    Serie: EKX2624,
    v/hz /ph : 400/50/3,
    A max: 739 A,
    On startup the pump is on, it indicates that the flow switch is ok but the system still shows no flow which makes the system not to run.
    Any hint in the right direction on what and parts I should check would be much appreciated.
    Thanks .
    Jun 2008
    Windsor, Ont.
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    What is the exact message that comes up? If the entering / leaving sensors are reading wrong it can give an alarm that points You towards flow but can actually be the sensors. With just the pump running both sensors should read very close.
  3. Likes stanbyyourword liked this post.
  4. #3
    ottawa canada
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Sometimes its Hard to start a Trane
  5. #4
    May 2020
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Error Message shown says "Excessive IPC comm loss "
  6. #5
    May 2020
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by nyrb View Post
    It says "Excessive IPC Comm Loss"
  7. #6
    Jun 2008
    Windsor, Ont.
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    https://hvac-talk.com/vbb/showthread...sive-comm-loss
    If you know how to use Techview, now would be the time. If not time to call someone familiar the system. Link above is for a similar situation that may or may not help.
  8. #7
    Dec 2019
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    On Techview after showing Excessive IPC common loss ..I went into binding and discovered that all the sensor have lost communication non is binded all red, even try to use magnet to light the sensor and see if it can be binded but it refused to bind..Any hint on what next to do
  9. #8
    Jun 2008
    Windsor, Ont.
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Disconnect 4 wire cable leaving panel to all field sensors / devices. See if panel mounted LLID’s are talking then. One bad cable or sensor can mess up everything. Familiarity is key and troubleshooting root cause may take a lot of time. I wish you good luck.
  10. #9
    Dec 2019
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Will do that, thank you
  11. #10
    Dec 2019
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Having done that,my new diagnostic on tranetech view now shows.
    Comm loss:suction pressure Cprsr 1A
    Comm loss: suction pressure Cprsr 1B
    Comm loss: EXV, CKT 1
    Comm loss EXV, CKT 2
    Comm loss: Oil Temp,CKT2 or Cprsr 2A
    Comm loss:Intmd Oil press,Cprsr 2A
    Comm loss:Intmd Oil press,Cprsr 1B
    Have tried binding them but not responding.
    Please what can to solved such problem.
  12. #11
    Jun 2008
    Windsor, Ont.
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Divide and conquer is the best answer I can give you!! Obviously something is faulty on that string of components.
  13. #12
    Dec 2019
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    So sir, Should I go ahead and change the components or their communication cable.
  14. #13
    Mar 2015
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    You have to narrow down which component is the problem by a process of elimination.
