Results 1 to 13 of 21
    Mar 2014
    Grand Blanc
    Another Retrofit
    Typical 20 year old home, uncomfortable homeowner, noisy equipment, multiple breakdowns. Cut equipment size in half per load calc, custom ductwork to improve airflow through equipment, sealed ductwork, balanced home airflow. Happy customer.
    Sent from my iPad using Tapatalk
  2. Likes kdean1 liked this post.
  3. #2
    Mar 2014
    Grand Blanc
    TESP, Cutting equipment size in half certainly helps but airflow entering and exiting equipment has the highest impact on TESP.
  4. Likes STEVEusaPA, kdean1 liked this post.
  5. #3
    Jan 2014
    New England
    I’d be curious as to what year that furnace was built, as from what I read Janitrol was last used as a name in 1992, making that furnace 28+ years old?
    Very nice install as usual.....is that the north side of the residence?.....a slight tripping hazard if that sprinkler head does not drop down..I suppose that’s what a inverted bucket is for...
  6. #4
    Mar 2014
    Grand Blanc
    Quote Originally Posted by Bazooka Joey View Post
    Id be curious as to what year that furnace was built, as from what I read Janitrol was last used as a name in 1992, making that furnace 28+ years old?
    Very nice install as usual.....is that the north side of the residence?.....a slight tripping hazard if that sprinkler head does not drop down..I suppose thats what a inverted bucket is for...
    House was built in 2003, data tag is a Goodman 2003 manufacture date. Goodman must of kept the janitrol tag for awhile.
    Thank you
  7. #5
    Atlanta GA area
    Back in my basement finishing days (late 1990's), before HVAC...
    Used Goodman equipment...
    That looks like one of those 'dependable 92' furnaces...
    They did work well... albeit figuring out how to set up the condensate tubing took a little head scratching.
    Once they were in... they worked fine!
    GA-HVAC-Tech
    GA's basic rules of home heating and AC upgrades:
    *Installation is more important than the brand of equipment
    *The duct system keeps the house comfortable; the equipment only heats and cools (and dehumidifies)
    *Cheap is not good, good is not cheap; however expensive is not a guarantee of quality!
    Choose your contractor wisely!
  8. #6
    Jan 2014
    New England
    Basement replacements are nice and a perk IMO, do you do any other equipment installs/replacement with new ductwork/modifications to existing in such places as in hot attics?
  9. #7
    Oct 2011
    Culver, Oregon (Central OR)
    Yep, those old rainbow stickers!! I put a few of those in between '01-'04. The drain setups were kooky, but they were pretty "dependable".
  10. #8
    Mar 2014
    Grand Blanc
    Im in Michigan so most of my installations are in basements. I am currently designing and installing a new system in an attic of a slab home. So not terrible as the home is gutted and Im not crawling around in old insulation.
  11. #9
    Mar 2014
    Grand Blanc
    My experience with the Dependable 92 is large cracks on the collector box and blown out HX on the first bend. I think the collector box was a manufacturing issue, HX failures due to over sizing, over firing and poor airflow.
  12. #10
    Oct 2011
    Quote Originally Posted by johoff34 View Post
    I found a lot of those guys with small holes cut in for the return. Worst one I saw was they only cut a 6"x6" square for the return. Goodman installers .
  13. #11
    That's newer than the Dependable 92. The GUN.
    34, amazing job. Never seen a system static that low.
  14. #12
    Feb 2011
    Georgia
    Another Retrofit
    These readings taken at the supply duct and return duct locations? If so this system is running more like .8 or 1.0? Only reason I ask is I see the holes drilled in the duct
  15. #13
    Aug 2009
    Michigan
    Bruh! I cant even. You think a guy that does a beautiful install like this dont know how to check static. This guy practically invented static. Beautiful work as always johoff34.
Contracting Business
HPAC Engineering
EC&M
CONTRACTOR
