+ Reply to Thread
Results 1 to 18 of 18
Thread: want to autopsy a compressor
    Dec 2018
    Ventura, CA
    Hi Guys,
    Whats the best way to open up a hermetic compressor? Grinder or ?
    Real curious as to how or why this scroll compressor took a crap.
    Southold, NY
    Quote Originally Posted by navyguy1 View Post
    Hi Guys,
    Best way it to send it back and let them do it. They’ll have the specs needed!
    Copeland will autopsy when requested for a price.
    Jun 2002
    nw ohio
    We usually used angle grinders.
    Always educational to cut them open!
    "Compressors never die; they're always murdered!" - Glenn Hannegan Jr
  4. Likes captube, ksefan liked this post.
  5. #4
    Dec 2018
    Ventura, CA
    Well I’m curious but not that curious. The cost for shipping alone wouldn’t justify it.
    Thanks though.
  6. #5
    Southold, NY
    Thanks though.
    1st dump the oil and measure. Look for acid and moisture.
    2nd Cut it open. Sawzall or grinder and a ton of filings inside.
  7. #6
    Mar 2018
    Virginia
    Ive used a grinder before...it's a bit of work but cool to see inside of them
    "I think Quantum tunneling would work great... "
    "Call a technician for God's sake. Or we'll see you on the news or the Dark Side of the Moon."
  8. #7
    Nov 2011
    Hi Guys,
    What kind of crap did it take? ..electrical or mechanical. Assuming you replaced it, find anything wrong with the system operation afterward?
  9. Likes JayMan7 liked this post.
  10. #8
    Dec 2018
    Ventura, CA
    Quote Originally Posted by Saturatedpsi View Post
    Mechanical crap. Compressor running but with both suction and discharge pressures the same.
    Any idea how a scroll can lose its ability to pump?
  11. #9
    Dec 2018
    Ventura, CA
    Replaced compressor and ac is working just fine now
  12. #10
    Southold, NY
    The scroll popped up during relief and never reset.
  13. #11
    Nov 2011
    That's as good a guess as any...there's also a "floating seal" that might not have been sealing.
    I've been studying 'em for years, seen all sorts of mechanical failure modes and still don't fully understand how they work or fail. You can click on the YT video link which will lead you to a bunch of autopsies and save you the trouble...
    https://www.youtube.com/watch?v=hapg3FbD9Es
  14. #12
    Hurst11 is offline Professional Member/Membership Committee
    May 2020
    Haskell Oklahoma
    A portable band saw works well and the gullet of the teeth on the band does a good job of dragging the shavings out. Doesn’t get em all but does better than sawzall.
  15. #13
    Poodle Head Mikey's Avatar
    Poodle Head Mikey is offline Membership Chair/ARP Committee / Professional Member*
    I try to stay as far away from myself as I can.
    Have your helper hold the shop vac hose next to the blade as you cut.
    Quote Originally Posted by Hurst11 View Post
    PHM
    When faced with the choice between changing one's mind, and proving that there is no need to do so, most tend to get busy on the proof.
  16. #14
    Apr 2020
    Garner NC
    there are youtube videos, that show a few.. the cam fails at the top...sometimes sheared off
    this is a running open one... https://youtu.be/9dCh3L3Y-iY
  17. #15
    Mar 2015
    Medford, N.Y.
    The Scroll itself could of snapped/busted.
  18. #16
    Apr 2020
    Garner NC
    this is a hermetic ...with valve damage..
    https://youtu.be/2j4SGkGs3vw
  19. #17
    Mar 2015
    Medford, N.Y.
    Quote Originally Posted by Unlimited1 View Post
    Post #1 says Scroll. And it is also a Hermetic.
  20. #18
    Mar 2018
    Kansas Flatlands
    Did a recip one time yrs ago with a sawzall, it took about $30 worth of blades by the time i was done.
+ Reply to Thread
Quick Reply Quick Reply
Register Now
Log-in
  • You may post new threads
  • You may post replies
