Volume as in How much refrigerant it holds? Unable to answer.
I am looking for the internal volume of a Goodman GSX140481KD condenser coil. Any idea where I can find this information?
R I P Icemeister
Supporting our Vet’s
http://www.soldierride.org/
http://www.woundedwarriorproject.org/
What about measurements of the coil for an estimate? I guess I could go outside and measure . . .
At the outdoor unit you will see that it consists of multiple rows of copper tubing attached to aluminum fins. There will be multiple rows of the copper tube going forth and back. We need to know the total length of the tube on each “row”, including the copper u-connector on one end, and we need to know the number of rows. We also need to know the outside diameter of the copper tube.
Just looking for a more exact route.
R I P Icemeister
I am considering the installation of the HotSpot FPH pool heater to provide free pool heating by recycling the waste heat that your air conditioner throws away. I live in Georgia and run my system from April 1 until Mid September. I have a 12,000 gallon pool.
I need to see if a 1- liter or so receiver will be needed if the internal volume of my Goodman existing air-cooled coil is substantially larger or smaller than the internal volume of FPH water cooled condenser coil. So, I need the unit coil face data.
It can be done but takes expensive materials, cupro-nickel Heat exchanger being the major expense. Add to that the average 3 ton A/C is at a minimum 5 X smaller then needed.
R I P Icemeister
best bet is to call the engineering dept.
I wonder if they make a water cooled condenser that could take pool water and just use your pool as a cooling tower
R I P Icemeister
Even decent sized heat pump pool heater takes days of constant runtime to heat a pool.
I saw this on ask this old house once.
Horrible idea.
My sister and BIL have a Rheem HP for their pool. Never have asked how well it does or does not work.
I just like the idea of setting the head pressure and walking away and use the pool as a heat sink. Depending on where you live you could do that with a heatpump too. I've worked on Lobster tanks, never seen an eel tank, dont think I'd be comfortable with a big old eel eyeballing me
Don't know why you would need a receiver.
