Thread: Dimmer on Four way circuits, and circuits with Four Switces?
    I think I know the answer, but want to check before I buy the $$$ LED Dimmer. Do you put the Dimmer on the SPDT Switch to get it to work, in conjunction with the other DPDT switches?
    Retired, after 43 Years
    Mar 2016
    Dayton Oh
    Quote Originally Posted by madhat View Post
    The ones I have in my house are a three way switch. Lutrons.
    Not sure if they make the 4 way switch in a dimmer. Think out load now, not sure of it matters if it’s at the switch with the load or the line. I have them both ways in various spots. Haven’t noticed problems... but then again never read of it matters.
    May 2019
    In my 55 years of electrical work, I've never seen a 4 way dimmer. (your DPDT referenced above)
    Proceed on the basis that the 4 way isn't even there.
    One S3 dimmer (SPDT) to replace only one of the S3 switches.
    Either end of the switching circuit......not 2 dimmers in the circuit.
    Some high end dimmers require a neutral connection which you may not have at either end.
    Get a dimmer that does't need a neutral.
