Results 1 to 13 of 14
Thread: Moms house
    Jul 2009
    Columbia, MD
    Moms house
    New 2ton heatpump, 2.5ton AHU. 10kw heater. New disconnect. New rocks, pad. Turning vanes in elbow
  2. Likes STEVEusaPA, Metalman0880 liked this post.
  3. #2
    Jan 2012
    Broomall, PA
    Tight! You always have to take care of Mom.
    If I do a job in 30 minutes it's because I spent 30 years learning how to do that in 30 minutes. You owe me for the years, not the minutes.
  4. #3
    Virginia
    you dont run into refrig issues when doing the larger AH with a HP ?
  5. #4
    Jan 2014
    New England
    Is the OD section complete? as you got a floating drier. Myself if they still make the brand and color of vinyl siding, I would buy a sheet or so and replace where the old disconnect switch was.
  6. #5
    Jul 2009
    Columbia, MD
    The only refrigerant issues ive ever run into due to different sizes is when doing a high velocity unit like unico.
    Recent was a 4ton unit.
    4ton unico indoor paired with 4ton trane hp. Rated airflow is 1250cfm. So obviously, issues there. But, apparently, if you use a unico outdoor unit, there are no issues.
  7. #6
    Jul 2009
    Columbia, MD
    I used hard drawn pipe. The siding is probably 30 years and aluminum.
    Good eye
  8. #7
    Aug 2001
    Pavilion, NY
    I haven't seen those pump ups.. they look nice along with the install
    Sent from my SM-N960U using Tapatalk
  9. #8
    Oct 2016
    Nice work!
    When I was doing industrial work a guy I worked with put a furnace in for his mother. He used sch 80 pipe and hd ftgs and put 1000lbs of n2 on the pipe for the inspector. The inspector was like dang man I need 10 psi. He said “I didn’t want Mama to have a leak”.
  10. #9
    Oct 2011
    Culver, Oregon (Central OR)
    Quote Originally Posted by kangaroogod View Post
    They are the pump ups designed to go with the Trane OD units. I personally hate them as they are a pain in the azz to install. Almost impossible to do yourself.
  11. #10
    Amarillo by mornin'
    Nice work. I like how the old one says 'Server Room'
    "It's not that I'm smart, it's that I stay with the problem longer”
    Albert Einstein
  12. #11
    id paint the piping
    Keep it simple to keep it cool!
  13. #12
    Feb 2015
    Coastal South Carolina
    Sharp.
  14. #13
    Jul 2019
    Oklahoma home its in the name
    Nice work. I really appreciate the gravel. Too many techs think it is beneath them to work with dirt.
    Sent from my "smart" phone using Tapatalk
Contracting Business
HPAC Engineering
EC&M
CONTRACTOR
