Results 1 to 13 of 28
    Jul 2009
    New Orleans
    Truck Stock - Start Capacitors / Start Kits
    I haven't really found anything specific regarding the subject of stocking start components for 1.5 - 5 ton split systems. I have many run capacitors and though start component failures aren't as common I'd like to have some components on hand. It seems that Trane is pretty finicky about OEM start components but are there some pretty common start cap and relay combinations that should be kept on hand or is the more practical route the universal start kits, if so which ones?
    Oct 2011
    Chicagoland Area
    Stock Supco SPP6 and SUPR and an assortment of run caps
  3. Likes ezrizer liked this post.
  4. #3
    Southold, NY
    All start components are common...…………..If you have the right size
  5. Dislikes ezrizer disliked this post.
  6. #4
    Jul 2012
    WA
    We don’t stock any start caps. We stock a hard start cap that I use to get them by until the right start cap can be ordered.
  7. Likes ezrizer liked this post.
  8. #5
    Mar 2015
    Medford, N.Y.
    If the ONLY thing you work on is as you stated (1.5 - 5T) AC ,then you might get by w/ the 5-2-1 relay/start cap kit'S or the Supco SPPE kit'S. The 5-2-1 kits ,which there are 3 all have 3 diff strength st caps. So why are there 3 diff size st caps? Even the Supco SPP(E) series of which there are 7 diff sizes use the 3 diff SPPE sizes to match up to the three 5-2-1 kits. The 3 "fairly" common st caps in those kits are 88-108 mfd,189-227 mfd & 270-374 mfd. Chose carefully and wisely. BUT, I suggest that you start a list of what the compressor maker ACTUALLY calls for and see for yourself that you are doing the right thing for the customers comp and your reputation.
  9. Likes ezrizer liked this post.
  10. #6
    Feb 2012
    Iowa
    Along with a variety of run caps, I just stock a couple of hard starts. Usually works until I can get the CD right start cap.
  11. Likes ezrizer liked this post.
  12. #7
    Mar 2015
    Medford, N.Y.
    I have around 20 diff Copeland start caps on-board as I do AC&R, and I like OEM exact parts.
  13. Likes ezrizer liked this post.
  14. #8
    Southold, NY
    Quote Originally Posted by ezrizer View Post
    So you don't like that How about this
    2.5, 5, 6, 7, 8, 9, 10, 12, 15, 20, 25, 30, 40, 50, 60, 70, 80, 90 & 100
    All 440 volt
    Now there are several micro caps but well save those for a later date.
  15. #9
    Virginia
    pay attention to the caps you come across and write them down.
    Get a couple to carry ... along with a supco "SUPR" Relay
    That relay is universal and will buy you plenty of time until you replace it with OEM
    I still have a couple out there waiting on OEM
  16. Likes ezrizer liked this post.
  17. #10
    Jul 2009
    New Orleans
    All 440 volt
    Thanks for the reply but I believe you have misunderstood my inquiry. The subject is starting components not run capacitors.
  18. #11
    Southold, NY
    Isn't a Run cap a Starting Component?
    That's pretty much all you'll have on a small unit like that!
  19. #12
    Virginia
    he evidently sees alot of choo choo trains
  20. #13
    Virginia
    I have all 3 of the 5-2-1 Compressor Savors (see attachments).
    I use the one that most closely matches the manufactures specs for the Start Cap MFD rating, and Potential Relay specs (pick up, drop out and continuous voltage).
    On Trane units, I only use their OEM start cap and relay.
  21. Likes ezrizer liked this post.
Contracting Business
HPAC Engineering
EC&M
CONTRACTOR
