condenser will not start
found unit 2.5 ton HP NORDYNE not running. Ahu working but no condenser.
Have 26.2 volts at R&Y and at C&R. So took defrost board off found lizard behind it.
Ordered board IMC-302C which i was told replaces Nordyne 917178A.
replaced board still will not run.
Originally Posted by
larryjack
If the "Y" terminal is energized at the defrost control by the thermostat calling for cooling, would you have 26.2 volts between "R" and "Y"?
What is the model number of this Nordyne Heat Pump?
larryjack
FT4BE 030
Thanks for the model number. Now can you answer my first question?
lets forget about that voltage.
What should have voltage when calling for cool?
You might want to call a service tech to determine what the malfunction is.
If you measured 26 volts from R to Y. Then you don't have a call to run.
larryjack
I am not trying to be sarcastic here - honestly.
Your profile states you are a technician, and a technician should know what the voltage should be between "R" and "Y" when a unit is calling for cooling, and what it should be when it's "NOT" calling for cooling.
Do you work for a HVAC company, or are you a "One Man Show", or are you really a home owner disguised as a technician?
Post Likes - 1 Likes, 0 Dislikes
rundawg
larryjack
Lets NOT forget about the voltage reading,whether you like it or not. I'll let other be all nice and easy on you,it seems that is not my style. As stated you DO NOT sound like a Tech. If you are a Tech you had better do some basic studying.
larryjack
24 Volts.
If you have voltage between r&y then you’re not calling for cool.
How long have you been a tech?
Jumpers can be your friend.
Adlerberts-Protege
He doesn’t know how to use a volt meter you think he’s safe with jumpers?
pecmsg
I said "can"...lol.
Larry, so what voltage did you have after you changed the board?
BNME8EZ
Larry, so how much $$$ was that board and what are you going to do w/ the old board?
I would be surprised, yet delighted, if we heard from "larryjack" again.
rundawg
Larryjack the HO?, I'd be surprised? or Larryjack the Tech?, I'd be delighted!!!!!!!!!
