Results 1 to 13 of 35
    Mar 2019
    condenser will not start
    found unit 2.5 ton HP NORDYNE not running. Ahu working but no condenser.
    Have 26.2 volts at R&Y and at C&R. So took defrost board off found lizard behind it.
    Ordered board IMC-302C which i was told replaces Nordyne 917178A.
    replaced board still will not run.
    Virginia
    Quote Originally Posted by larryjack View Post
    If the "Y" terminal is energized at the defrost control by the thermostat calling for cooling, would you have 26.2 volts between "R" and "Y"?
    What is the model number of this Nordyne Heat Pump?
    Mar 2019
    FT4BE 030
    Mar 2019
    FT4BE
    Virginia
    FT4BE 030
    Thanks for the model number. Now can you answer my first question?
    Mar 2019
    lets forget about that voltage.
    What should have voltage when calling for cool?
    You might want to call a service tech to determine what the malfunction is.
    If you measured 26 volts from R to Y. Then you don't have a call to run.
    Virginia
    I am not trying to be sarcastic here - honestly.
    Your profile states you are a technician, and a technician should know what the voltage should be between "R" and "Y" when a unit is calling for cooling, and what it should be when it's "NOT" calling for cooling.
    Do you work for a HVAC company, or are you a "One Man Show", or are you really a home owner disguised as a technician?
  10. Likes vin lashon liked this post.
  11. #10
    Jan 2010
    Quote Originally Posted by rundawg View Post
  12. #11
    Mar 2015
    Medford, N.Y.
    Lets NOT forget about the voltage reading,whether you like it or not. I'll let other be all nice and easy on you,it seems that is not my style. As stated you DO NOT sound like a Tech. If you are a Tech you had better do some basic studying.
  13. Likes thatguy liked this post.
  14. #12
    Southold, NY
    24 Volts.
  15. #13
    Jan 2019
    Vero Beach, Florida
    If you have voltage between r&y then you’re not calling for cool.
    How long have you been a tech?
Contracting Business
HPAC Engineering
EC&M
CONTRACTOR
