+ Reply to Thread
Results 1 to 8 of 8
Thread: trane/american stand question
    Mar 2016
    Dayton Oh
    on the silver 80 model add1b is there a y2 terminal on the board.
    I can find almost all other info on the unit other than that one.
    Those are history, PSC motor. Sure don't remember a Y2 on the board. Is there a Y1 also? What's the full model #?
    Mar 2016
    Dayton Oh
    History? It’s a 17....... .
    Hopefully it doesn’t have a y2 so I can play around and throw after market relays on moms unit so I can slap in a 2 stage ac
    Mar 2016
    Dayton Oh
    hey thank you much. need the fan speeds from there as well. much appreciated.
    fan speeds are in that pdf
    Mar 2016
    Dayton Oh
    Meant to put needed not need. Thanks again
    Poodle Head Mikey's Avatar
    Poodle Head Mikey is offline Membership Chair/ARP Committee / Professional Member*
    I try to stay as far away from myself as I can.
    PSC motor 'speeds' are not actually different speeds - they are more like different HP points. So the end-result 'speed' is highly dependent on duct static - that is: the end-result 'speed' is dependent on the 'slip' of the motor. The various speed taps reduce available HP to the point where it cannot overcome the discharge static and it slows because it is physically (not electrically) over loaded.
    If I were going to do what you are suggesting I would wire an NC closed contact to supply power to the cooling-speed you are using now and wire the NO contact to supply power to the same speed wire but series it through a motor speed controller. They are cheap - less than ten dollars - and will enable to to dial the suction temperature to down where it should be on the low speed AC mode.
    I keep hearing that they tear up motors - but so far that has never happened for me.
    PHM
    Quote Originally Posted by jbhenergy View Post
    PHM
    When faced with the choice between changing one's mind, and proving that there is no need to do so, most tend to get busy on the proof.
+ Reply to Thread
Quick Reply Quick Reply
Register Now
Log-in
  • You may post new threads
  • You may post replies
