Leak Detector Frustration
Ugh. I just tried to use my SLR8 leak detector and couldn’t find anything on a small R22 package unit. Getting a bit suspicious I checked it’s efficacy on a hose fitting I loosened. I could hear the gas coming out but the detector barely responded. It’s less than a year old so it shouldn’t need a new sensor. It’s not the first SLR8 I’ve had lose ability after a year or so. Anyone have a suggestion for another more reliable detector? I’m going to get a new sensor for this one but I want another one to use when this one doesn’t pick up a leak.
My only suggestion is change the filter more frequently and carry big blue.
Sent from my "smart" phone using Tapatalk
"Is this before or after you fired the parts cannon at it?" - senior tech
I'm tired of these mediocre "semi flammable" refrigerants. If we're going to do it let's do it right.
Unless we change direction we are likely to end up where we are going.
"It's not new, it's better than new!" Maru.
SLR8 is not the best detector for R22. SLR8 is the cat's meow for r410a. Do a you tube search for Nathan's HVAC
Doug
Post Likes - 3 Likes, 0 Dislikes
Originally Posted by
R600a
Yeah, I actually took off the filter and then the tubing to rule out a restriction. Big blue is nice, but it sometimes sets off the detector so I try to use it only after I’ve already “sniffed” for leaks
Achso017
I was meaning change the filter more frequently to extend the life of the sensor.
And carry big blue for when you are leak checking r22 or if it fails on 410a.
I had one the other day that leaks 2 lb of r410a every few years and I couldn't find it with the srl8 because I didn't have time to let the coil dry completely so I just used big blue and I found it right away. I love that stuff.
Gunslinger
Ok, I’ll do that. Thanks.
R600a
Nice. I’d say ~75% of the indoor coil leaks I find are in the fin pack and it would take too much big blue to soak the whole thing but I do squirt the joints after I use the sniffer.
Achso017
Exactly. We don't repair leaks that are actually in the coil. So often I use the method from the leak detection manual where you disconnect the drain on a dry coil and put the probe in the drain for 10 minutes and if it doesn't trigger then it isn't the coil. If it is the coil then I open it up an grab the big blue to check the spots that I could repair.
Gunslinger
That brang up some good videos. I like the H10 vs srl8 one. It was interesting. I may have to buy an inficon for r22.
Another thing I have done is to run a heat pump in heat.. The pressure is higher.
Doug
R600a
Oh my. My spelling.
get a tekmate for r22- and the srl8 for 410a. Yes its a pain. I got an h10 instead of the srl8 because I have a cps leak "wanna be" seeker---it finds NOTHING, tekmate- perfect for r22, dtek- perfect for r22, 134A, and ok for 410a, bacharach (ultrasonic)--good for coil leaks and flare leaks, and the h10 pro which is what I use 90% of the time- the other 10% is divided among the others (not the cps). that is the most worthless piece of garbage I have ever used.
get a tekmate for r22- and the srl8 for 410a. Yes its a pain. I got an h10 instead of the srl8 because I have a cps leak "wanna be" seeker---it finds NOTHING and was tired of multiple leak checkers for different situations. I also have tekmate- perfect for r22, dtek- perfect for r22, 134A, and ok for 410a, bacharach (ultrasonic)--good for coil leaks and flare leaks, and the h10 pro which is what I use 90% of the time- the other 10% is divided among the others (not the cps). that is the most worthless piece of garbage I have ever used.
My tekmate was 40$ at pawn shop- new. They said "we don't think it works"---and it was because the sensor was still in the sealed package---hahahaha. Loved it.
Check pawnshops. There is a jb 5000 prowler at one here for 40$. I just dont need it or I would buy it. They are supposed to be pretty good.
I might add- no one beats inficon for customer service. They will take care of any issue- quickly and without questions. That alone is why I will always buy their product if it is what I need vs competitor products.
Post Likes - 1 Likes, 0 Dislikes
mtsaz100
Thanks. I’ve heard some good things about the tekmate
Just another random gripe: don’t look for a leak after you’ve washed the outdoor coil with renewz. Found out the hard way awhile back on a maintenance.
I usually wash the coil first thing so it has a chance to dry and I can check the charge with a known clean coil. I found the system low and got approval for leak search. Started indoors and sure enough, fin pack leak.
Checked lineset and when I pulled the top to check the coil and tubing, I couldn’t even get the detector inside the cabinet before it started screaming. With some experimenting, some head scratching and some wasted time i figured out it was the cleaner residue on the bottom of the pan. Had to wash it a few more times with the hose and remove all debris before I could check it.
D-Tec Select. Best detector I’ve ever used. If it doesn’t beep, there is no leak.
The only other detector I’d consider is the H-10.
If God didn't want us to eat animals... He wouldn't have made them out of MEAT.
The inficon i tried recently did good with the h10 reference bottle. Not near as good as the h10 though in practice.
GenesisRefrig
Select is horrible. H10pro is great for 22 and ok for 410a.
Slr8 is great for 410a and horrible on 22.
The select barely picks up anything compared to those 2
JB prowler 5000, for the win..
Sent from my moto g(7) power using Tapatalk
"If you can’t describe what you are doing as a process, you don’t know what you are doing." ~ W. Edwards Deming
All those who wander..are not lost.
Do NOT..mistake my kindness for weakness.
The early bird may get the worm..but the second mouse gets the cheese.
I have an older H10 (not PRO) I use for R22... seems to be more sensitive to 22 than the newer PRO...
For 410... use the H10 PRO... seems to wok better on 410.
Yeah, the H10's are expensive... however they just work!
Anyone have one of the old H10 plug in models... it is really sensitive to 22... however has to be plugged in and is kinda finicky to work with... got mine years ago from another contractor...
GA-HVAC-Tech
GA's basic rules of home heating and AC upgrades:
*Installation is more important than the brand of equipment
*The duct system keeps the house comfortable; the equipment only heats and cools (and dehumidifies)
*The value of comfort, over the long term; leave economic choices behind!
Choose your contractor wisely!
