Page 5 of 6 FirstFirst 123456 LastLast
Results 53 to 65 of 67
  1. #53
    Apr 2014
    San Jose California
    Your customer couldn’t afford it. Did you fix it for free.
    I can see at least 4 to 5 hours of labor, adding R-22 and as preventative maintenance maybe you added the easy seal.
  2. #54
    Aug 2018
    Piedmont Triad, NC
    Quote Originally Posted by Core_d View Post
    Im not running around in the cock sucking bull shit peanuts... suck my dick. My truck starts for money and it turns off for exhaustion. Been doing it for years, little sympathy for those that cant respect that.
    ROFLMAO!! Honestly made me laugh out loud. *thumbs up*
  3. #55
    Jul 2012
    WA
    I think part of the reason for the vastly different viewpoints and experiences is due to commercial vs residential. In residential I’ve seen more evap leaks. In commercial I’ve seen more condenser leaks. Not sure why. Doing mostly commercial/industrial work, I fix any leaks that can be fixed. If the equipment is in poor condition, I’ll discuss replacement with the customer. They usually want it repaired if possible. They understand that there is no guarantee that new leaks won’t develop at any time.
    For resi work, in the case of the OP, I would’ve recommended unit replacement, but if they wanted it repaired and understood the risks I would’ve done the repair.
  4. #56
    Apr 2020
    Garner NC
    Its not much of a difference if the terminology of RTU/Package and Split systems is used..both residential and commercial have them..
  5. #57
    Oct 2014
    Saint Pail, Minnesota
    Happens everyday in the commercial end.
    Saw it on a dual pressure control where each cap tube had rubbed through and been repaired 3 times.
  6. #58
    Jul 2012
    WA
    Quote Originally Posted by Unlimited1 View Post
    I’m talking about large tonnage equipment that costs tens of thousands of dollars, or even more, to replace. The tendency is going to be to repair if possible.
  7. #59
    Apr 2020
    Garner NC
    Ok, I’m still working on 30+year old 7.5 ton and up to 20 ton carriers that are being replaced with curb adapters and trane RTUs in their place. They have a timeline budget that they do for replacement. I can easily make the carriers last a long time...very simple technology! No complicated fancy control circuit boards, lol I definitely going to miss them!
  8. #60
    May 2020
    In this difficult times you gotta do what you gotta do to get by. Good job lol
  9. #61
    If you stick them together with a bead of silicone caulk - that will stop happening.
    Quote Originally Posted by Pnasty View Post
    PHM
  10. #62
    May 2014
    Bay Area California
    I just put a tie wrap or two on it.
    Quote Originally Posted by Poodle Head Mikey View Post
  11. #63
    Jan 2010
    or just make sure their not touching each other ....
  12. Likes Achso017 liked this post.
  13. #64
    Mar 2013
    Treasure coast, FL
    Even cap tubes need to socially distance.
    Sent from my Moto Z (2) using Tapatalk
  14. Likes Achso017, BBeerme liked this post.
  15. #65
    Jan 2010
    Quote Originally Posted by shellkamp View Post
    Good luck with that 🙄
Contracting Business
HPAC Engineering
EC&M
CONTRACTOR
