Results 1 to 13 of 15
    May 2018
    TRANE CHILLER (CH530) ON OVERLOAD TRIP COMPRESSOR 2B
    When the chiller starts running compressor 2B is always the first to always picks, i discovered the compressor 2B starts with a high starting current of about 670Amps (which is not normal) immediately the overload trips alarm comes up and generator powering the chiller shutdown due to this high starting. Pls why is the compressor 2B pulling this high current and popping up this alarm?
    Mar 2017
    Orange County, CA
    Nobody will be able to answer that question based on what you wrote.
    May 2018
    What I meant is that whenever the compressor 2B picks an overload trip compressor 2B alarm comes up, could it mean something is wrong with the compressor?
    Nov 2011
    East Side
    Chiller model?
    May 2018
    The chiller model is RTAC 300tons
    Jan 2010
    What's the letter after 300 in the model number ?
    Also digit #27 ( a number )
    Apr 2018
    Compressor is probably starting fully loaded. Possible stuck slide valve.
    May 2018
    @ VTP99, From the name plate: The chiller model is Trane RTAC375DEZ0HCUFXW3XYXBAXXX1H33XLDAEXX meaning the chiller is a RTAC (Rotary Air-cooled chiller with a capacity of 375 Nominal Tons
    Salt Lake City/Tooele
    Manufactured near the town of, Remulak.
    Jan 2015
    Somewhere making cold water
    Bearings most likely going bad. Perform a vibration test if it ever start, that data will tell you bearings.
    Metro ATL
    Quote Originally Posted by WYLBEK View Post
    My money is on the slide valve being stuck or rotor locked. Either way you need to isolate and evacuate the compressor and do some internal checks. The tolerances in these compressors is so tight that a bearing failure typically ends up manifesting itself in the form of a locked rotor. Slide valve issue = field repairable. Bearing issue/locked rotor = compressor replacement.
    Also, is this across the line or y-delta start? A compressor trying to start in the delta configuration can also cause high amp draw and trip.
  12. Likes milkyway liked this post.
  13. #12
    Mar 2018
    check for loose electrical connections
  14. #13
    Nov 2015
    this fault may because of below following issues
    Check the condition of unloading solenoid coil (Should energize before start the compressor)
Contracting Business
HPAC Engineering
EC&M
CONTRACTOR
