Results 1 to 11 of 11
    Oct 2019
    Confused emergency switch button
    What will be the consequence of frequent using of emergency switch button when shutting off chiller?
    Southold, NY
    Why are you using it?
    My carriers push it once and the chiller would slowly ramp dawn and shut off. Push it twice and full shut off, then back spin. No oil was being pumped during these few seconds just like a power failure. No good for the machine.
    Oct 2019
    We used the emergency button because when OFF button was pressed on the touchscreen it wont activate. However, all the other buttons were functioning normally.
    Southold, NY
    Quote Originally Posted by YROLL View Post
    Does it go thru a normal shutdown or just immediately stop?
    Oct 2019
    Yeah it stops immediately (turbocor compressor)
    Nov 2011
    East Side
    Turbo core is a maglev shaft. When you hit E-Stop, the shaft crashes into the touchdown bearings, instead of slowing, stopping, then setting down on the bearings. Continued crash will likely cause bearing issues.
    Mar 2017
    Orange County, CA
    Are you referring to a WMC? If so, open up the control panel, you can shut off the compressors individually, and they will shutdown normal.
    ottawa canada
    Its called “Emergency Stop” for a reason .
  9. Likes stanbyyourword liked this post.
  10. #9
    Jun 2008
    Windsor, Ont.
    Assuming this is the Multistack chiller from your other post.... the E-stop should be a digital input to the chiller control system which should disable all running compressors immediately. The compressors themselves should shutdown more or less normally as they should still have main power to spin down and then de-levitate the shaft.
  11. #10
    Oct 2019
    Multistack
  12. #11
    Sep 2009
    So Cal
    On the MultiStack, you should be able to hit the system switch on the top right corner of the display to shut down the Chiller Locally. If that's not working, then have the Rep reprogram that function.
    Air Treatment Corp is the local rep in this part of the woods and they did that config adjustment for a job site that I'm on. That chiller starts/stops via remote Hardwired Enable Command on DI-1 from the BMS System. The engineers can go up to the chiller and shut it down locally by tapping on the system switch on the display.
Contracting Business
HPAC Engineering
EC&M
CONTRACTOR
