Page 1 of 4 1234 LastLast
Results 1 to 13 of 45
    Mar 2020
    Run AC with Rusted Out Heat Exchanger?
    I have a package unit gas pack and AC. I discovered in January the heat exchanger is rusted out and I need a new unit. So I heated with the gas logs until tax return time. Now I'm wondering why can't I run the AC and put this expense off even longer lol. Any safety problem with that?
    Southold, NY
    Quote Originally Posted by CUfan99 View Post
    Why put off until tomorrow what you can put off until day after!
  3. Likes CUfan99 liked this post.
  4. #3
    Virginia
    None. As long as you are not turning the gas burners on, you can run the AC all day long.
    Please prepare to replace this unit in the late summer, as you do not want to operate this system with a known cracked heat exchanger (HX) this next heating season.
  5. Likes CUfan99 liked this post.
  6. #4
    Mar 2020
    My man!
  7. #5
    Mar 2020
    Quote Originally Posted by rundawg View Post
    Fabulous! Thanks for the piece of mind and sharing the knowledge!
  8. #6
    Oct 2011
    Culver, Oregon (Central OR)
    Make sure and turn the gas valve off outside the furnace though, just in case someone else turns the stat to heat.
  9. Likes CUfan99, ga-hvac-tech, ziggyhere liked this post.
  10. #7
    Mar 2020
    Follow-up question for you guys. Any idea why the fan runs constantly with the stat Off and fan setting on Auto? The only way I can turn it off is by flipping the breaker off.
  11. #8
    Southold, NY
    Could be a safety tripped or bad relay. Doesn't matter much your going to be replacing it anyway.
  12. Likes CUfan99 liked this post.
  13. #9
    Virginia
    Now we are getting into troubleshooting, which this forum does not allow.
    Only testing with a Volt Ohm Meter will determine the actual cause, and prevent guessing, which is in no ones best interest.
    I am curious of the model number of this unit though?
  14. Likes CUfan99 liked this post.
  15. #10
    Atlanta GA area
    What part of the country are you in???
    Just curious...
    GA-HVAC-Tech
    GA's basic rules of home heating and AC upgrades:
    *Installation is more important than the brand of equipment
    *The duct system keeps the house comfortable; the equipment only heats and cools (and dehumidifies)
    *Cheap is not good, good is not cheap; however expensive is not a guarantee of quality!
    Choose your contractor wisely!
  16. Likes CUfan99 liked this post.
  17. #11
    May 2014
    Bay Area California
    The only thing I can add would be to schedule the work for the off season. Might get more competitive pricing.
    I do a triple evac with nitro to remove non condensables.
  18. Likes ga-hvac-tech, CUfan99, Turtleman liked this post.
  19. #12
    Oct 2014
    Saint Pail, Minnesota
    Quote Originally Posted by BBeerme View Post
    Or even right now. Everyone is currently sitting at home waiting to work.
    But I understand OP hesitation before rebate comes.
  20. Likes CUfan99 liked this post.
  21. #13
    Jan 2010
    One advantage of waiting is you prolong your up and coming warranty.
  22. Likes CUfan99 liked this post.
Contracting Business
HPAC Engineering
EC&M
CONTRACTOR
