Results 1 to 20 of 27
Thread: Possible to get AC in a townhouse while keeping condenser inside and vented out?
Previous Post Previous Post   Next Post Next Post
    Mar 2020
    I live in a townhouse where we are not allowed to have mini split or regular air conditioning due to changing the appearance outside and drilling holes through the wall blah blah.
    Is there a way to hookup a regular AC or mini split or anything for that matter inside and have it vent out through a basement window?
    I currently have 2 portables which are not very quiet. It's really hard to find those as well
    Not practically. Since a conventional A/C would require a way for a large amount of ait to enter the basement to cool the condenser, and would need a blower added to it to force the high volume of air, the condenser needs.
    A 1.5 ton A/C air handler would only need to move 600 CFM of air, while the 1.5 ton condenser would need to move 1200 to 1400 CFM of air to keep it cool.
    Southold, NY
    Quote Originally Posted by equlizer36 View Post
    So what do they have for A/C currently besides portables?
    Jul 2000
    Northern Wisconsin
    Does the covenants give any suggestions other than "suffer at the expense of making the property look good"? What if anything has your neighbors done to get around this restriction?
    Jan 2014
    New England/Florida
    Chances are the electrical data plate on any outdoor section A/C or Heat Pump will say something like this “ For outdoor use only “
    Mar 2020
    Everyone else has loud portables and or fans. Now that i am on the board, i will try and change this by getting everyone to purchase the same unit/color and from the same company and maybe get everyone to sign a waiver that if anything happens with it outside, we are responsible.
    Southold, NY
    What was originally there?
    Where is this condo located?
  8. Likes Nuclrchiller liked this post.
  9. #8
    Aug 2009
    Prattville, Alabama
    This ^
    In honor of RichardL: "Ain't 'None' of us as smart as 'All' of us".
  10. #9
    Southold, NY
    You need a Mechanical contractor and a site visit. We cant see the building or its location.
  11. #10
    Is there forced air heat now? Or baseboard?
  12. #11
    Mar 2020
    All units are forced air. I can get anything that does not protrude past the window frame. Everyone here is in the same boat.
  13. #12
    SW FL
    AVOID HIGH DENSITY POPULATIONS @ALLCOST$.!
    https://www.carnival.com/cruise-ships.aspx
    Designer Dan __ It's Not Rocket Science, But It is SCIENCE with Some Art. _ _ KEEP IT SIMPLE & SINCERE ___ __ www.mysimplifiedhvac.com ___ __ Define the Building Envelope & Perform a Detailed Load Calc: It's ALL About Windows & Make-up Air Requirements. Know Your Equipment Capabilities
  14. #13
    Jan 2010
    No flat roof area ?
  15. #14
    Mar 2020
    no flat roof
  16. #15
    Jan 2010
    Would be nice until you received your next water bill
    Here they base your sewer bill off water consumption so double trouble.
  17. #16
    Jan 2019
    Vero Beach, Florida
    You can do the first company through the wall condenser.
  18. Likes equlizer36 liked this post.
  19. #17
    Madison, WI/Cape Coral, FL
    Quote Originally Posted by Deathpunch0311 View Post
    You asked me about the optimum moisture removal of a coil by making colder than the desired dew point in the home.
    Using the saturated temperature of the coil for ideal setup is best. The saturated temperature should be a minimum of 10^F below the desired dew point of the home.
    Ex/ 75^F,50%RH, a 55^F dew point should have supply air with minimum of 50^F supply dew point conditioned air.
    Important also is the outdoor air temperature when making the adjustment needs to be typical load condition.
    Hope this helps clear the air.
    Regards Teddy Bear
  20. #18
    This is the A/C deathpunch mentioned. It is mounted flush to the wall. Common in multi-family. Then hooks by refrigerant lines to a coil in the air handler.
  21. #19
    Jan 2010
    I don't think the association will allow wall penetrations.
    Sounds like an association living in the stone ages.
  22. #20
    Jan 2019
    Vero Beach, Florida
    Thank you baldloonie.
Quick Reply Quick Reply
Register Now
Log-in
  • You may post new threads
  • You may post replies
