Page 3 of 6 FirstFirst 123456 LastLast
Results 27 to 39 of 67
  1. #27
    May 2019
    Does the compressor ID tag match the cond unit ID tag as far as 1 or 3 phase?
    If somehow a 3 phase compressor ended up in a 1 phase cond unit, and then the replacement was based on the compressor ID tag the problem would repeat itself.
  2. #28
    May 2003
    Comp model
    ZPD54K5E-PVF130
    208/230 1 Ph
    Actual voltage 239
    Run cap 100mfd, checked at 99.7
    Amps and voltage were checked at contactor.
    Amp Draw is 11
    It does have an unloader but not digital, it's off the scroll head, unit does have HGRH, valve was checked, check valves at reheat coil are in correct direction, all valves were checked and open
  3. #29
    Mar 2015
    Medford, N.Y.
    Quote Originally Posted by rimide View Post
    Comp model
    ZPD54K5E-PVF130
    208/230 1 Ph
    Actual voltage 239
    Amp Draw is 11
    PVF in that MN#???? Even if it is PFV, that ain't right
  4. #30
    Southold, NY
    Run Cap 100 / 370
    230 1 phase
    60 Hz
    LRA 134
    RLA25.6
  5. #31
    Southold, NY
    Copeland Mobil app calls for 100 / 370
    OPI calls for 80 / 370
  6. #32
    Jan 2010
  7. #33
    Southold, NY
    That still doesn't explain whats going on.
  8. #34
    Jan 2010
    Agree where's the other numbers asked for ?
  9. #35
    Mar 2015
    Medford, N.Y.
    Quote Originally Posted by TechmanTerry View Post
    My mistake(again) I was looking at the 50hz info
  10. #36
    May 2003
    What other numbers do you need
  11. #37
    Jan 2010
    Two bad compressors has to be one in a thousand.
  12. #38
    Jan 2010
    Condensing unit if split or package number if RTU.
  13. #39
    Mar 2015
    Medford, N.Y.
    Just one more thing that IDK about. Why is an unloader used on a digital Scroll when the digital part controls/matches the comp load from 100% down to 10%???
Contracting Business
HPAC Engineering
EC&M
CONTRACTOR
