Results 1 to 12 of 12
    Jun 2012
    Northeast
    Question Digital manometer fluctuations
    Who is using digital manometers for checking gas pressures? I have UEI and Fieldpiece. Both fluctuate readings which make it difficult to get an accurate measurement. It is like they need a surge chamber or something. The technology is just not there yet to dampen out the readings and provide an accurate average.
    I have the Fieldpiece SDMN5 and the SDMN6
    I have 2 of the UEI EM151
    Aug 2009
    Michigan
    I have the testo 510. Ive used it for 5 years or more now. I like it. Its great for residential. If you need something for a larger range, I like the Dwyer 475. It will measure up to 5#s.
    Jun 2012
    Northeast
    Quote Originally Posted by HAWK 87 View Post
    I have the testo 510. I’ve used it for 5 years or more now. I like it. It’s great for residential. If you need something for a larger range, I like the Dwyer 475. It will measure up to 5#s.
    Do you use it on gas? I do not see anything saying it is used for anything but air.
    Aug 2009
    Michigan
    Yes
    Dec 2012
    columbus, OH
    They are accurate enough, my question would be what would you achieve by having this gained accuracy?
    Jun 2012
    Northeast
    Quote Originally Posted by Core_d View Post
    Its not they are not accurate. The reading bounces. I just want a stable reading. Right now I try to look at the higher readings and lower then pick the middle when taking my numbers for my notes. It is annoying. I would rather not have to.
    Salt Lake City/Tooele
    Use a snubber.
    Jun 2012
    Northeast
    Quote Originally Posted by slctech View Post
    Use a snubber.
    One for a water pressure gauge? Those are all I am aware of.
    Jun 2014
    Dover, DE
    I have the SDMN6, this hasn’t been an issue.
    I’ve used it for Modine Atherion commissions, where I have to read accurately down to 0.25”.
    I havent failed. Ive just found 10,000 ways that wont work. - Thomas Edison
    Its not whether you get knocked down, its whether you get up. - Vince Lombardi
    Quote Originally Posted by Push It View Post
    No different, fluid is fluid whether air or gas. I deal with all types of fluctuating and erractic measurements whether nitrogen, air, natural gas, argon, CO2, etc. Thinking something revelent to our industry would maybe be trying to read the outlet gas pressure of a Lennox or Fulton Pulse, without a snubber your gas pressure readings with a digital manometer would be all over the place, with a snubber your readings are stabilized.
  11. Likes Push It liked this post.
  12. #11
    Apr 2018
    They all bounce around a bit i have used UEI fieldpiece and testo. Its not the fact that there not accurate its that there too accurate that is why your readings are all over the place. Make sure that when your taking your readings that you mount the manometer flat on something or set it in one stop and try to keep it there. (most have a magnet on the back) and the biggest thing is to always zero it out before you take any readings.
  13. #12
    Dec 2012
    columbus, OH
    How much bounce are we talking here?
Contracting Business
HPAC Engineering
EC&M
CONTRACTOR
