Results 1 to 13 of 15
    Apr 2018
    Replacement fan motor?
    I’m working on a Harford freezer with RDI evaporator coil. Two of the four fans quit this week. The EC motors are very short front-to-back and have a threaded shaft. I couldn’t find anything at Aireco that would work so I called Heritage parts for OEM. My price on the motors is $XXXXXXX each! Does someone know of a reasonable replacement?Name:  IMG_1645.jpg
    Virginia
    I just went through the same thing
    I bought 2 fans and bent over without any KY jelly to pay for them .....the new motors lasted 1 year
    Im like screw this
    Took all 3 fans out , tossed them .... no actually Im pretty sure I hurled them with great force ..... into the trash pile, went and bought the typical fan setup you see in Heatcraft freezer , the brackets , motors , blades , problem solved
  3. Likes bacciagalupe liked this post.
  4. #3
    Jan 2010
    You could practically by a new evaporator for that price.
    ECM = junk !
  5. #4
    Jun 2009
    DFW, TX
    https://www.mcmillanelectric.com/products/4064s-2/
    I've used this one successfully
    Sent from my SM-G892A using Tapatalk
  6. #5
    Jan 2016
    The triangle in the Keystone
    RDI coils are built by HTGP and It’s not as easy to change them over to a PSC motor. If your gonna get rid of the ECM then the brackets and fans need replaced too.
    I had better luck with Heatcraft coils where the original fan and brackets could be reused.
  7. #6
    Apr 2018
    Thanks to everyone who replied. I wound up with a simple solution to get my PSC motor in there. Four 1/4-20 coupling nuts and some threaded rod were used to extend the bracket arms. It still barely fits after sawing off the front studs and what’s left of the rear ones. I put Locktite on the extensions so...fingers crossed.
  8. Likes VTP99 liked this post.
  9. #7
    Virginia
    pics or it never happened
  10. #8
    Virginia
    Here is the one I did
    I only had to drill larger holes for the brackets to poke through , and like you , cut off the studs on back of motor so they don't rub through the coil
  11. Likes pecmsg, BobFrost liked this post.
  12. #9
    Apr 2018
    Gorgeous pics! I need to take more. That’s exactly the motor and bracket I was working with. The Bohn bracket is probably the best choice but I couldn’t find them locally and I was in a pinch. I almost went to my old boss because I know he’s got used ones. I was happy to not put more money in his pocket. My bracket extensions work well...if they hold together. I’ll report back if they explode the coil.
  13. #10
    i hope you wrapped the wire nuts in electrical tape i always do or shrink tubing
  14. #11
    Apr 2018
    Here’s a pic for Snapperhead. Also note that doing this way requires a new blade.
  15. #12
    Virginia
    Quote Originally Posted by pctech View Post
    i squeeze silicone RTV in them
  16. Likes BALloyd liked this post.
  17. #13
    i have done that as well heat shrink tubing is the best but more work to remove later on
Contracting Business
HPAC Engineering
EC&M
CONTRACTOR
