Page 10 of 14 FirstFirst ... 34567891011121314 LastLast
Results 118 to 130 of 179
  1. #118
    Jan 2010
    She could measure the width and that would narrow it down to two .
  2. #119
    Jan 2014
    New England
    But were still waiting on the Model #
  3. #120
    Houston,Texas
    I looked up the coil, it's around 17.5" X 17.5" X 21.5" so the furnace could be a 40,000 to 60,000 just looked bigger to me.
    “Experience is a hard teacher because she gives the test first, the lesson afterwards" ~ Vernon Law
    "When the teachers become unteachable we're all in trouble"
    "It's what you learn after you know it all that counts." ~ John Wooden
  4. #121
    Atlanta GA area
    Looking at the pic... looks like B width (17.5")...
    If so, and if the chart on the link is accurate...
    Then 4 choices. Probably is either a 40K or 60K...
    We do not as of yet know what AC unit the installing contractor planned to use... so my guess is the 40K/3T drive.
    If we get a pic of the furnace guts... we can count the burners...
    GA-HVAC-Tech
    GA's basic rules of home heating and AC upgrades:
    *Installation is more important than the brand of equipment
    *The duct system keeps the house comfortable; the equipment only heats and cools (and dehumidifies)
    *Cheap is not good, good is not cheap; however expensive is not a guarantee of quality!
    Choose your contractor wisely!
  5. #122
    Jan 2010
    Oh wait, the 40 overlaps ....
  6. #123
    SW FL
    As long as your the one signing the check
    ______________ you should be called The Boss.
    Stop the job for 72 hours until you can get an
    independent review on what’s designed and what’s there.
    It’s your money.
    WINDOWS __ S.H.G.C. 0.17 __ U-factor 0.29
    Total glass area 92 sq feet
    ________ West _ 70
    ________ East _ 22
    Walls R-19
    Floor R-20
    Ceiling R-20
    Floor Area is actually 702 Sq feet
    Kitchen, Living and Bedroom is essentially one room with a divider wall.
    + Closet & Bath
    Drawings ( 9/03/2019) have not been updated to show foamed insulation on the roof rafters.
    Moreover, the Attic is actually specified as ventilated - 100 CFM.
    A louver is shown on the attic space upper wall.
    The roof is specified as METAL.
    AND The residence front actually faces WEST ( NOT EAST as stated verbally / written in this thread ).
    Drawing North arrow points DOWN.
    ORIENTATION Verified using GOOGLE EARTH on the address provided via e-mail.
    Any way IN THE MIDST OF THIS CONFUSION, I came up with
    __ Q. Sensible = 8,500
    __ Q. Latent … = 3,000
    __ Q. Total .... 11,500 BTU/HR
    ONE-Ton HEAT PUMP Mini-Split ...
    __________ ____ ___ I AM DONE with This.
    ____ KEEP IT SIMPLE
    __________ www.mysimplifiedhvac.com
    Designer Dan
  7. Likes BALloyd, mofotech liked this post.
  8. #124
    Southold, NY
    Quote Originally Posted by dan sw fl View Post
    ________ West _ 70
    ________ East _ 22
    Walls R-19
    Floor R-20
    Ceiling R-20
    + Closet & Bath
    Thanks again Dan
  9. #125
    May 2013
    Quote Originally Posted by ga-hvac-tech View Post
    Good for you on stopping the job until it is resolved.
    Flex duct is not a bad thing (it has a bad rep)... as long as it is installed correctly.
    What I would be concerned about with the supply plenum... is it having internal insulation... which has in the past been a 'petri-dish' for organic growth...
    We use metal plenums... we seal all the connections, then wrap them with insulation. Do not see any insulation on that one...
    The mastic (white or grey, clumpy paint) holds the tape in place... tape does not stick to mastic... so the tape goes first.
    Mastic should be 2MM thick (think-ness of a nickel-- $0.05)... general rule of thumb: if you can see through it, it is not think enough. Its best quality is holding things together and plugging holes.
    All these things, of course, are labor intensive... which raises the price of the work.
    Better, IMO to get it done now... than later!
    Good thing... is most of your ductwork will be accessible later... if something needs to be done.
    I have read here about installing the flex correctly, pulling it tight, not compressing, not looking like an octopus. Interesting about the supply plenum, didn't know that, love learning something new. I will look the next trip, oh and ask for the information, too. I knew about mastic, learned that here.
    Actually, the builder called the stop until I decide what I want. I wish he had run the equipment by me before letting it get installed.
  10. #126
    May 2013
    As long as your the one signing the check you should be called The Boss.
    Stop the job for 72 hours until you can get an independent review on what’s designed and what’s there.
    It’s your money.
    Working on it, good advice, thanks.
  11. #127
    May 2013
    If you are having the attic foamed... that means the foam is on the underside of the roof...
    And you will need a condensing furnace... vents through PVC pipe, not through a metal pipe.
    The furnace now installed is NOT a condensing furnace... so it will NOT work with a foamed underside of the roof.
    Advise: make a list of all the issues... you are gonna need it...
    I did not know that about the foamed roof and the condensensing furnace and PVC vs metal pipe. I am making a list, You'all have contributed to that list. Thanks, and I know I need it.
  12. #128
    May 2013
    Everything up there is going to be covered in FOAM!
    The guys spraying the foam are completely covered in Tyvek suits with respirators, and full face masks. So there saying there going to pull the flex away while they foam? BS
    All that should come out as well as the furnace and coil.
    I am going to verify that with the builder and get it in writing. I agree it needs to come out, foam and then do the installation. Good advice and I appreciate the heads up.
  13. #129
    May 2013
    Is it just me, or the picture? That furnace looks big, If it's a 75,000 she could always convert this space into a sauna in the future.
    Funny but not.
  14. #130
    Oct 2011
    Culver, Oregon (Central OR)
    The drain is done improper as well.
Contracting Business
HPAC Engineering
EC&M
CONTRACTOR
