Page 9 of 14 FirstFirst ... 234567891011121314 LastLast
Results 105 to 117 of 179
  1. #105
    Southold, NY
    Quote Originally Posted by Chris1584 View Post
    Seriously, I am thinking about it. I worry they will just label me a b#@+^. If it was my husband they would be conferring about it I am sure. Not because he would be more knowledgeable, he would, but it's a guy thing, at least in this situation. I DO NOT get that feeling here at all, thank you for that.
    As long as your the one signing the check you should be called The Boss.
    Stop the job for 72 hours until you can get an independent review on what’s designed and what’s there.
    It’s your money.
  2. Likes ga-hvac-tech liked this post.
  3. #106
    Atlanta GA area
    You went there! Attachment 814830
    OK Bill...
    If I ever get down there... we will need to get together again... been too many years...
    How are John and Cindy doing???
    Have not heard from them in a LONG time!
    GA-HVAC-Tech
    GA's basic rules of home heating and AC upgrades:
    *Installation is more important than the brand of equipment
    *The duct system keeps the house comfortable; the equipment only heats and cools (and dehumidifies)
    *Cheap is not good, good is not cheap; however expensive is not a guarantee of quality!
    Choose your contractor wisely!
  4. #107
    Atlanta GA area
    I asked for a conditioned closed attic, with cellulose am I getting that? And with a gas furnace in a closed attic do I need outside air brought into the unit? And where will the dehumidifier go, does it get mixed with the air coming from the cold air return?
    If you are having the attic foamed... that means the foam is on the underside of the roof...
    And you will need a condensing furnace... vents through PVC pipe, not through a metal pipe.
    The furnace now installed is NOT a condensing furnace... so it will NOT work with a foamed underside of the roof.
    Advise: make a list of all the issues... you are gonna need it...
    GA-HVAC-Tech
  5. #108
    Atlanta GA area
    It’s your money.
    Thoroughly agree!
    GA-HVAC-Tech
  6. #109
    Jan 2010
    Thoroughly agree!
    X 2
  7. #110
    Southold, NY
    I asked about the flex right next to the roof line and how they do the foam. I was told they pull it out of the way, foam, and them put it back. Is there a problem with the flex duct touching the foam? I believe cellulose is going in the walls, and then foam between the ceiling of the garage and the floor of the apartment.
    Everything up there is going to be covered in FOAM!
    The guys spraying the foam are completely covered in Tyvek suits with respirators, and full face masks. So there saying there going to pull the flex away while they foam? BS
    All that should come out as well as the furnace and coil.
  8. #111
    Atlanta GA area
    Just my opinion: If the underside of the roof is gonna be foamed...
    This should be done BEFORE the HVAC is put in... or the HVAC equipment should be covered with a droppie... keep the splatter off it.
    GA-HVAC-Tech
  9. #112
    Houston,Texas
    Is it just me, or the picture? That furnace looks big, If it's a 75,000 she could always convert this space into a sauna in the future.
    “Experience is a hard teacher because she gives the test first, the lesson afterwards" ~ Vernon Law
    "When the teachers become unteachable we're all in trouble"
    "It's what you learn after you know it all that counts." ~ John Wooden
  10. #113
    Southold, NY
    Whats the smallest gas furnace Trane Makes? 60K?
  11. #114
    Jan 2010
    No model number for the furnace yet ?
  12. #115
    Atlanta GA area
    Someone said 26K...
    However I think it is 40K...
    Regardless... sometimes we have to determine the furnace size by the AC capacity...
    And we have found that a PSC (yeah, I know, they are not available anymore) 3 ton drive... usually will not handle sloppy 3 tons of ductwork. We always use a 4 ton drive with 3 ton AC... which means a larger furnace... which means using a VS furnace with 2 stages... most of the time the heat never gets out of low stage.
    But then... we are in a primary AC market... so AC performance takes front row, and heat performance is second row...
    Houston is more that than we are.
    GA-HVAC-Tech
  13. Likes mofotech liked this post.
  14. #116
    Jan 2014
    New England
    Here it is again... https://www.google.com/url?sa=t&rct=...89-qiMf6yEE1Zs
    26K input.... according to current web-site 9 tap ECM motor.
    The coil says it’s rated from 18,000 - 36,000 BTU according to Trane web-site, not a straight 3 ton.
    https://www.google.com/url?sa=t&rct=...L-Sksl2jeAPSMW
  15. #117
    Southold, NY
    Quote Originally Posted by Bazooka Joey View Post
    But were still waiting on the Model #
Contracting Business
HPAC Engineering
EC&M
CONTRACTOR
