Results 1 to 11 of 11
    Mar 2020
    Post Our walk-in freezer will not stop running
    The compressor on my walk-in freezer will not stop running. Our contractor replaced some electrical parts and still the problem was not resolved. He walked away about two months ago mumbling something about replacing a bad expansion valve but never showed up again. Any ideas of what is wrong? To save the life of the compressor, we have been manually cutting power to the compressor for about 12 hours each day. The defrost cycle works and the circulating fans go off inside the freezer when it goes into defrost but the compressor keeps running. I do not want to pay another contractor until I have some idea what is wrong so that I do not repeat the same misdiagnoses. Where should he or she look for problems?
    Jan 2010
    How is the temperature controlled ?
    Jun 2014
    Dover, DE
    X2 on temperature control.
    Is this a new freezer? Has it ever run correctly?
    Should be a fairly simple electrical diagnosis.
    I havent failed. Ive just found 10,000 ways that wont work. - Thomas Edison
    Its not whether you get knocked down, its whether you get up. - Vince Lombardi
    Mar 2020
    It is controlled by a thermostat inside the walk-in. The thermostat has been replaced. The freezer reaches and holds the proper temperature.
    Mar 2020
    This walk-in has been in operation for about 15 years without problems.
    Jan 2010
    This should be a simple fix for a competent tech.
    Isn't there one available in your area ?
    Mar 2020
    Apparently not. We live halfway between San Antonio and Austin. We are about an hour from each city. Any ideas what it could be. What is the expansion valve and is it inside the freezer or near the compressor?
    Jan 2010
    Walking you through a walk-in cooler repair is one thing walking you through a walk-in freezer would be twice as hard.
    There's that much more involved. Without the proper testing tools would even make it more difficult.
    Unfortunately here on this site we are not allowed to offer one do yourself information. The temperature control could be configured different ways to control the temperature.
    There is a contractor locator map on this forum have you looked there for a company near you ?
    Aug 2008
    Hibbing, MN
    Could be your solenoid valve, pressure controls, contactor, wiring, etc. This should be a very elementary problem to solve. Call someone else.
    If God didn't want us to eat animals... He wouldn't have made them out of MEAT.
    Jun 2014
    Dover, DE
    There’s no way of us being able to tell you exactly what the issue is without walking you through DIY troubleshooting, which this site doesn’t allow.
    But this issue should be simple for any half experienced tech to diagnose.
    Southold, NY
    Is this box indoors or out?
    Whats the pressure and temperature readings.
    Walls compromised?
Contracting Business
HPAC Engineering
EC&M
CONTRACTOR
